mounting rear wing on hatch
04-14-2007, 03:50 AM
i have bought an aftermarket fiberglass hatch wing and after speaking to a friend at a body shop need some advice as how to get it 'flush mounted', securely fixed and possibly with drainage.
from the sides where the wing wraps around the glass, we are unsure how blend the join into the body. using fiberglass would take a considerable amount and it could possibly crack in the future as the wing is used to pull open the hatch. is there any other possibilities????? he suggests using polyeurethane to hold the wing to the hatch surface, but we both agreed that it may need more strengthening than this. however i cannot stand the site of those wings i see held on with rivets all the way around them. my friend suggested using a few screws ocassionally around the perimeter of the wing (the ones with the end caps to conseal their appearance. is there any other possibilties??????? from all pictures i have seen, these style wings have no drainage watsoever! the hatch will then tend to rust out as the wing will affectively be a bird bath. is it therefore better (or possible?) not seal the perimeter entirely and allow drainage through hatch surface and wings underside surface? advice and suggestions would be much appreciated aaron (zenki 83 levin) |
04-14-2007, 10:07 AM
Stock wing use bolts. Try to fix your wing similar manner (maybe you can fix some screws on the bottom of the wing and use stock holes in the hatch for bolts). Stock wing uses rubber strips at the contact area (with the hatch) - you can buy such rubber elements from some hardware stores (if you have aluminium/PVC door and windows manufacturing companies, they can sell you rubber seals). For example rubber strip with V-profile will work fine.
http://www.alibaba.com/productsearch/Window_Seal.html |
04-18-2007, 04:22 AM
Well, I fabricate, sell and apply TRD style Rear wings, and by my experience the normal procedure is to:
1-Place the wing in its place 2-Drill holes separated around 10cm from each other all around the wing (drill wing and boot alltogether) 3-Rivet all the holes Optional - Fiberglass or Polyester Mass on top of the rivets and for a smooth finishing. Easy and wont break or tear. ![]() |
Horn mounting... | Mylesmck | 6 | 2,706 |
07-12-2023 10:03 AM Last Post: Mylesmck |
Can Wing Mirror Glass be Replaced? | chrisae86 | 1 | 1,692 |
03-05-2023 09:34 PM Last Post: Ivan141 |
Converting Jap Spec wing mirrors to UK spec | chrisae86 | 5 | 3,253 |
04-12-2022 11:03 PM Last Post: chrisae86 |
Exhaust fumes in cabin (Hatch seal problem!) | Lt86 | 16 | 22,423 |
11-13-2015 01:20 PM Last Post: pack |
GT Wing options | 4000GT | 10 | 22,651 |
06-19-2014 07:34 AM Last Post: 4000GT |
