multiple rear axle problems!!
03-07-2011, 05:09 PM
Hi,
I finally got time to install all my parts!
But there are some problems, and I´d like to have a few opinions Smile:
http://img9.imageshack.us/i/214.mp4/
This was taken last year, eversince I bought all new bearings and a solid spacer and it will get a complete new allignement, done by specialist.
Does a TRD diff get the same settings as a stock unit?
C/P gear doesn´t look to bad, so this should cure the problem (at least become less noisy)?
Another problem with the wheelbearings.
I bought a slidehammer to get them out, but I could pull the left axles with a slight tap, an the other one by hand!
Aren´t they supposed to be fu**** tight in there?
One bearing has play and rusty stuff comming out of it, so i needs replacing, the other one seems fine, but I think I´ll replace it, too just to make sure it is fine.
I´ll use some loctite shrink disc connection to get it a little tighter in there.
What you think?
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
03-07-2011, 05:42 PM
The loose half shafts are a result of repeatedly pulling them out.. They probably get locked in place by corrosion over time.
You can put a light layer of loctite or something similar in there to lock them up, just be sure you'll be able to remove them again later.
I doubt a r&p that has been noisy before will ever get completely quiet again.
03-08-2011, 05:28 AM
Thanks, ok so nothing to worry about! Hurray!
From memory, if you can´t remove loctite shrink connection 300°C will allways do.
Well, I just hope the C/P will last a little longer, once it´s realigned...
03-12-2011, 10:09 AM
I always grease or anti-sieze the bearings when reinstalling so they're easy to pull later on. Be happy yours came out no problem.
TRD gears get the same specs as OEM. As long as the gears aren't chipped/cracked/damage you should be ok. Noisy gears can last as long as quiet ones, but your sanity might not make it Wink . You might be able to quiet it down somewhat if setup was off, but it'll never be completely quiet.
Andrew
03-14-2011, 02:07 PM
Ok sweet!
BTW I drive with earplugs Banging head
  AE86 rear axle weight megabob 11 20,747 03-29-2024 11:18 AM
Last Post: FanIsHere
  Axle width totta Crolla 1 1,705 10-24-2023 12:20 PM
  Big wheel problems gh0st 16 10,354 11-15-2021 10:51 PM
Last Post: gh0st
  Starting problems 4-AGE kouki Hanzo 3 3,365 08-31-2021 06:20 PM
Last Post: totta Crolla
  Bluetop Engine Rebuild multiple question Goal 150-160hp Hanzo 16 11,687 04-19-2021 10:08 PM
Last Post: Hanzo
