my hachi don't want to start...
01-08-2008, 07:33 PM
Hi all.
I have a big probleme with my 86. It don't want to stard. I have rebuild the engine. with some trd pistons. the engine whene i'll start it tung en run until 2000/2600 rpm but it stop. here a vidéo. http://www.dailymotion.com/boodream/video/6691868 I have tested the ingintion. it's OK. The distribution is OK too. And the engine has the fuel. I have put an AE92 fuel pump in. I realy don't know why it don't start. The engine as never start since i've got it. So please if some one as a probleme like this or know how to resolve it. let me know ![]() Thanck you. Best regards BOOMEX.
SR Team BURN THE RUBER NOT YOUR SOUL! |
01-08-2008, 08:51 PM
The doube relay that feeds the fuel pump is working?
Is the one that sits beside the glove box, black with the connector yellow. Keeping the AE86 alive! |
01-08-2008, 10:25 PM
Yes, sound like a problem with your fuel delivery.. the pump always gets 12v during starting, but after that, the circuit-opening relay needs to kick in to keep the fuel coming.
01-09-2008, 01:29 AM
That's it Ivan
Let's see if that's BOOMEX's problem... Keeping the AE86 alive! |
01-09-2008, 08:43 AM
Ok thanck you guys. i'll see it this afternoone when i'll come back from The univercity.
![]() TY SR Team BURN THE RUBER NOT YOUR SOUL! |
01-09-2008, 08:59 AM
When the ignition is turned ON do you have 12 volts
present at the injectors ?? Cheers... jondee86 The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man. |
01-10-2008, 12:08 AM
I have cheked that relay today.
It works properly. the fuel pump works too. I tested to run the pump directly from the batery. The engine still makes the same. Tomorow i'll test what the injectors get. Thanks. B.R BOOMEX SR Team BURN THE RUBER NOT YOUR SOUL! |
01-11-2008, 12:05 AM
check mass cables. You have 3 of them. one is connected to the manifold runners, near to the injectors. 2nd is on the back of the left valve covers, and 3rd is below left engine mount.
check for fuel - from the fuel line after the filter. disconnect the fuel line from the rail, try to start the engine and look at the disconnected fuel line check for spark - from spark plug cables. disconnect one of them, put some spare spark plug inside, touch it to ground and try to start the engine. 84' AE86 Levin 96' 500HP WRX, powered by landikar
| Refreshed 20v blacktop first start.. | Mylesmck | 6 | 2,499 |
| Warm start problem | DJexor | 5 | 4,008 |
| Mistlamps don't fit | gh0st | 1 | 3,165 |
10-14-2021 09:00 PM Last Post: banpei |
| Weak spark, doesn’t start. | AlexFourTwenty | 4 | 17,782 |
| Won´t start | AlexKTM | 6 | 19,665 |
12-04-2017 10:05 PM Last Post: banpei |
