my hachi don't want to start...
01-08-2008, 07:33 PM
Hi all.
I have a big probleme with my 86.
It don't want to stard.
I have rebuild the engine.
with some trd pistons.
the engine whene i'll start it tung en run until 2000/2600 rpm
but it stop.
here a vidéo.
http://www.dailymotion.com/boodream/video/6691868
I have tested the ingintion. it's OK.
The distribution is OK too.
And the engine has the fuel.
I have put an AE92 fuel pump in.
I realy don't know why it don't start. Crying
The engine as never start since i've got it.
So please if some one as a probleme like this or know how to resolve it. let me know Wink
Thanck you.
Best regards BOOMEX. Wave
SR Team
BURN THE RUBER NOT YOUR SOUL!
01-08-2008, 08:51 PM
The doube relay that feeds the fuel pump is working?
Is the one that sits beside the glove box, black with the connector yellow.
Keeping the AE86 alive!
01-08-2008, 10:25 PM
Yes, sound like a problem with your fuel delivery.. the pump always gets 12v during starting, but after that, the circuit-opening relay needs to kick in to keep the fuel coming.
01-09-2008, 01:29 AM
That's it Ivan Thumbs up!
Let's see if that's BOOMEX's problem...
01-09-2008, 08:43 AM
Ok thanck you guys. i'll see it this afternoone when i'll come back from The univercity.Wink
TY
SR Team
01-09-2008, 08:59 AM
When the ignition is turned ON do you have 12 volts
present at the injectors ??
Cheers... jondee86
01-10-2008, 12:08 AM
I have cheked that relay today.
It works properly.
the fuel pump works too.
I tested to run the pump directly from the batery.
The engine still makes the same. Banging head
Tomorow i'll test what the injectors get.
Thanks.
B.R BOOMEX
SR Team
01-11-2008, 12:05 AM
check mass cables. You have 3 of them. one is connected to the manifold runners, near to the injectors. 2nd is on the back of the left valve covers, and 3rd is below left engine mount.
check for fuel - from the fuel line after the filter. disconnect the fuel line from the rail, try to start the engine and look at the disconnected fuel line
check for spark - from spark plug cables. disconnect one of them, put some spare spark plug inside, touch it to ground and try to start the engine.
84' AE86 Levin
96' 500HP WRX, powered by landikar
[Image: AEU86 AE86 - my hachi don't want to start...]
  Refreshed 20v blacktop first start.. Mylesmck 6 1,115 10-07-2024 07:55 AM
  Warm start problem DJexor 5 2,629 03-09-2023 10:15 AM
  Mistlamps don't fit gh0st 1 2,427 10-14-2021 09:00 PM
  Weak spark, doesn’t start. AlexFourTwenty 4 16,064 12-12-2017 03:35 AM
Last Post: AlexFourTwenty
  Won´t start AlexKTM 6 17,909 12-04-2017 10:05 PM
User(s) browsing this thread:
