my last work , Dentist needed
03-28-2013, 11:54 AM
I need a dentist............
Just after 500m , into a rally stage , no noises before , and suddently, a big CRACK , and i stopped . No more move possible . It'(s) was a TRD gearbox , , now a silent one . I guess it's impossible to get parts to repair The 4th gear pinions are both dead , but I think that the one on input shaft can't be changed (remaing stock on TRD gear set) But It can be removed from input shaft. I can use a stock one from the output shaft. Any advices welcomed . Defenatly too hard to drive with a stock gear box (4,7:1 gear end). Always between 1st and 2nd gear in 90° corners. regards Phil Filh Save the RWD cars |
03-28-2013, 02:00 PM
Does your rally class allow a gearbox conversion? I think a Ford gearbox would be much easier to maintain and find replacement parts for.
03-29-2013, 12:09 AM
Thanks Ivan
If I can't find a reasonable offer , I'll probably go for that. Regards Phil Filh Save the RWD cars |
03-29-2013, 01:27 AM
it is the drop gear that is broken 4 th are 1:1 and involve any gears
03-29-2013, 07:47 AM
^ as he said.
That's your input shaft to countershaft gears that are stripped. 1,2,3,5 & R. 4th locks input and output together and should still work. New gear set or new transmission. Andrew |
How seatbelt rails work? | FanIsHere | 2 | 4,688 |
05-18-2016 09:52 AM Last Post: Bean |
How does the 4age AFM system work? | heshan | 22 | 24,339 |
12-20-2012 05:01 AM Last Post: heshan |
my tvis doesnt work... | daywalker | 30 | 47,970 |
02-19-2012 01:25 PM Last Post: ZDoman |
few issues after last drift days, advice needed | fax0815 | 3 | 4,787 |
08-26-2011 08:33 AM Last Post: jondee86 |
Work equip 01 max offset?? | stalker | 5 | 9,380 |
08-23-2011 03:09 AM Last Post: Lewy |
