need help combining 4AC block with 4AG head
05-16-2007, 10:21 AM
compression ratio as far as i knw
05-16-2007, 10:27 AM
so do i need to change the piston or can i leave it as it and just pop on the head on the 4AC block with out any problems would it give me major problems ....
05-16-2007, 10:50 AM
Major problems - I think - no.
Are you from USA ? On Ebay you can buy CHEAP new 4AGE pistons, get rings also and make 4AGE even with 4AC conrods and crank. It will work for everyday use.
05-16-2007, 11:05 AM
No i am in south Africa... i and the piston here is a bit pricey
05-16-2007, 12:05 PM
Changed the topic title to something a little more meaningfulSmile
Max, you found a 4AG head but no 4AG block?
How about getting a 7AFE engine and putting the 4AG head on that? :
http://www.club4ag.com/faq%20and%20tech_...d%207A.htm
http://www.aeu86.org/index/engine-4age-t...post=60902
05-16-2007, 12:37 PM
Max_toy Wrote:No i am in south Africa... i and the piston here is a bit pricey
Okay, try to get some like these:
http://cgi.ebay.com/ws/eBayISAPI.dll?Vie...:IT&ih=007
There are also Clevite brand pistons (proven good enough) and rings at similar prices. I hope you can buy them from South Africa ?
05-28-2007, 07:41 AM
hi
i was able to pick up a set of 4Age pistons and a crank for free... and all in a good state... so this all will pop in to my 4A-C block and off we go
05-28-2007, 07:44 AM
so this is what i have
> Bluetop 4Age head
> manifold
>all gaskest
>inake weber manifold
>weber carb 32.36
>4Age pistons + crank
>rings + bearings
>4A-c block
05-28-2007, 09:52 AM
So you must find conrods only.
05-28-2007, 10:53 AM
sorry forgot about that got the conrods ...
  Need help identifying this! takumi_mt 4 898 04-05-2024 09:17 AM
Last Post: takumi_mt
  Question about 4AG 20v Engine Block CHACAMAN 1 1,580 06-10-2022 05:17 PM
Last Post: oldeskewltoy
  TRD ECU need help ps13michi 5 3,806 02-18-2022 10:42 AM
Last Post: ps13michi
  Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP mister86 12 10,826 02-10-2020 06:39 PM
Last Post: Power_uP
  4AGE block differences explained (incl. some eyecandy) Bean 46 86,474 05-05-2019 04:03 AM
Last Post: Rocker100
