nzae86's TRD ae86 N2 Race Car Project 2,
09-27-2009, 06:35 AM
Post: #221
porn!!
09-27-2009, 07:39 AM
Post: #222
oooooooh caaaarbon....
I like it A LOT! TokyoSeven For all your performance needs : Japan Direct! Web: www.TokyoSeven.com FaceBook: http://www.facebook.com/tokyo.seven?ref=profile AE86 ADDICT! |
09-27-2009, 10:05 AM
Post: #223
dazed_driver Wrote:Nice dash/seat/belts/airbox. Oh, and the stack. I really want one... hahaHi there The dimensions of the air box are Length = 400mm Height = 180mm Width = 140mm Hope this is of some help Your addiction to motorsport can only be cured by poverty !! |
09-27-2009, 10:13 AM
Post: #224
mc68 Wrote:mate, got a part# or model for the blower you used for the demister? was a cut of ally used to get it to fit onto the heaterbox? This blower is a TMC brand and its air flow is 122CFM , I just went to the local marine shop and purchased this as a bilge blower for use in a boat.The old heater box I gutted everything out of it and made new baffles inside it to direct the air through the heater core ,and only out the top to the windscreen .Then used some aluminum to make a plate for the end and mounted the blower to it.The intake for it is through a plastic bend and draws air from outside through the original place under the dash. Hope this is useful ! Your addiction to motorsport can only be cured by poverty !! |
09-27-2009, 01:01 PM
Post: #225
very very helpful, thankyou!
Brake with the left hand, steer with the right foot... |
09-27-2009, 10:38 PM
Post: #226
why do you use a airbox ?
http://bruutt.blogspot.nl/ Projects: Lancer evo 4 rs, ae86 drifter, carina ta60 4a-ge & ae82gt twin cam.. |
09-29-2009, 11:31 AM
Post: #227
einneb Wrote:why do you use a airbox ?By using an air box you can draw cold air away from the engine and with the filter further away from the end of the throttle bodies there is no interference with the air speed and flow. Your addiction to motorsport can only be cured by poverty !! |
09-29-2009, 02:10 PM
Post: #228
ah oke
10-01-2009, 06:22 AM
Post: #229
Today the final hole in the body shell was filled with a new laminated windscreen, also another interesting discovery made as well . I lot of people here have had trouble getting a new replacement screen for these cars as the new ones all appear to be too short .Toyota have made two different scuttle panels that fit under the windscreen , one fits the original toughened glass screens from the factory and the other fits the cars that left the factory with a laminated screen that is shorter in height .All that can be purchased here in NZ is a laminated screen .
Here is a photo of the two different panels Well you learn something everyday! Nice and shiny!! Managed to get a bit of work done on fitting the dash in and fitting up the center console, this takes the reservoirs for the master cylinders on the pedal box , also it will give me something to mount the fuse boxes and relays to as well so the inside is starting to come together finally . Your addiction to motorsport can only be cured by poverty !! |
10-01-2009, 04:37 PM
Post: #230
I noticed that on my windscreen too when I replaced it due to a chip/crack, although the laminated screen I took out wasn't original either. I should have ordered the shorter panel when I got new sides and top trims... but the longer panel is ok (If it was short panel short screen then )
I maybe would have mounted the remote reservoirs on the firewall behind the dash just to keep the interior less congested... but makes for easy access and keep fluid levels in check. RokuSteady : Shakotan - Tsuraichi - Hippari - Onikyan : 神奈川 様式 |
nzae86's AE86 Levin Tarmac rally car build Project 1 | nzae86 | 30 | 56,007 |
04-30-2013 07:28 AM Last Post: nzae86 |
my celica race car with race beams | Celica RA45 | 14 | 20,655 |
09-14-2011 11:50 AM Last Post: Celica RA45 |
AKR's Daily-driver-race-car | asian knight rider | 5 | 10,501 |
11-01-2009 12:25 AM Last Post: doggy |
My Project car :D | Muchomuchacho | 5 | 6,555 |
06-05-2008 05:15 PM Last Post: Muchomuchacho |
A.D.D Performance Demo car (AE86 project) | cab32 | 15 | 17,600 |
03-24-2008 03:34 PM Last Post: cab32 |
