o2 sensor and rough idling
10-30-2008, 02:14 AM
Hey this topic mite have been talked about before.
On my ae86 trueno i see theres 2 sensors one near the top of the exhaust manifold and one near the bottom of the manifold. Its just that the bottom one is cut off and im wondering if i need it.
At the moment it runs abit rich as i can smell the fuel coming out of the exhaust and im worrying about emissions when i MOT it near late december time.
Also when the engine is warm or after a thrashing it struggles to idle properly it dips from 900rpm down to 5-600rpm and bounces back up.
Ive cleaned the filter, checked vacuum lines and they seems to be fine
any ideas ???
will try and get pics up on the sensors
10-30-2008, 07:41 AM
the second lower o2 sensor looking things is actually exhaust temp sensor for your cluster, has nothing to do with ecu.
Running rough when warm could suggest busted plugs and/or leads
Idle hunting can be a dirty throttle body, or dizzy out but a tooth.
Steve.....this is sparrrrrtan
11-12-2008, 06:53 AM
hi there..
i'm new comer,
my engine had similar problem with u alex,
but my check engine directly appears when the engine was warm,
i've check with my friend,they suggest to change new that sensors
11-19-2008, 04:01 PM
hmmm.... ic ic my lights was fine nothing came on when running
the porblem i found now is that its something to do with eleco or ground (i think) as it gets worse when i put radio, heater and lights on i have bought a grounding kit with voltage stabilizer just waiting for a gd time to put it on
11-19-2008, 04:02 PM
11-26-2008, 07:52 PM
installed earthing kit with voltage stabilizer and idle is still rough moving up and down alot only when i put the front fogs on when they are off its less rough
plugs was new 6 months ago so gonna change leads, dizzy cap and rotor arm and see
11-26-2008, 08:06 PM
don't forget to check your TPS setting :wink:
11-26-2008, 08:08 PM
how do i do that ? im abit of a noob lol
  Lambda sensor wiring sam3007 10 5,472 05-23-2022 10:00 PM
Last Post: The Doctor
  AE86 Engine Coolant Temp Sensor izanagi 8 21,574 09-06-2014 05:47 PM
Last Post: izanagi
  Hall sensor totta Crolla 7 8,895 02-28-2014 10:07 AM
  Video : Adjust the TPS (Throttle Pos Sensor) on the 4A-GE Homem Bomba 3 11,877 10-25-2013 05:13 PM
Last Post: Apsogos
  Engine not idling right Jezza_hr 28 25,160 10-01-2013 08:43 AM
Last Post: jondee86
