oldskull's Levin
11-08-2009, 07:32 PM
Post: #331
oldskull's Levin
cannabolic Wrote:vinegar Vinegar in the radiator to clean them? 1985 AE86 (ハチロク) Levin - Summer time daily driver |
11-08-2009, 07:59 PM
Post: #332
oldskull's Levin
yupp!
Just poor it and let it stay there for some time. Philip |
11-08-2009, 08:04 PM
Post: #333
oldskull's Levin
I already removed the old radiator, so I need to put vinegar in my new radiator and let it for a day of something? and should the motor also must be started for cleaning the engine?
11-08-2009, 08:19 PM
Post: #334
oldskull's Levin
So the one on the pics is your new or old radiator?
Here I did a quick google and found this. http://www.merkurencyclopedia.com/Coolin...clean.html Philip |
11-08-2009, 08:22 PM
Post: #335
oldskull's Levin
that is the old one.
The new one is brand new never use 1985 AE86 (ハチロク) Levin - Summer time daily driver |
11-08-2009, 08:46 PM
Post: #336
oldskull's Levin
The new one is new
But you still have some shit in the system ---> block, head, hoses, etc. I would do some kind if provisional setup, without the radiator and run the engine to clean the system. Philip |
11-08-2009, 08:52 PM
Post: #337
oldskull's Levin
connect the bottom hose to the top inlet
11-08-2009, 09:53 PM
Post: #338
oldskull's Levin
I need to clean the system not the radiator...
Len, I will try that. 1985 AE86 (ハチロク) Levin - Summer time daily driver |
11-09-2009, 09:16 AM
Post: #339
oldskull's Levin
Open up all water outlets (bottom rad hose, bolt on exhaust side of engine block) and let a garden hose run some water through it a few times.
Or what I did before replacing a rad: run your system on tapwater for a short run, and flush it completely. Repeat two times, this way the water will take up a lot of the crap left in the system. FABRICA MI DIEM, PVNC! |
11-09-2009, 02:43 PM
Post: #340
oldskull's Levin
Thanks,
I am thinking about to put the old rad back, and going to buy a special pill for cleaning the system with motor running this way I believe the rust in the system will go. and then do the flushing with water after that. 1985 AE86 (ハチロク) Levin - Summer time daily driver |
