p-nuts drift trueno ae86 project(20v)
03-22-2006, 07:51 PM
Post: #31
robokill Wrote:maybe he wasn't going full out ? It looked that way, trowing the gears down and full throttle... But how many of this cars drive in the netherlands ? I´m not sure anymore who i saw driving that sunday around 22:30 @the A7 @purmerend ? No no no noooooooooooooooooooo |
03-22-2006, 07:54 PM
Post: #32
of these there is another one but its a difrent colour and hasn't run for years. anyways than it wasn't fast maybe a small problem ?
03-22-2006, 07:58 PM
Post: #33
robokill Wrote:of these there is another one but its a difrent colour and hasn't run for years. anyways than it wasn't fast maybe a small problem ? It sure was a twotone grey black car... No no no noooooooooooooooooooo |
03-22-2006, 08:34 PM
Post: #34
something tells me that if P-nut thinks he has a nice car to play with, the thing will be pretty fast, but a7 purmerend sounds like the place to spot him
He attacked everything in life with a mix of extrordinary genius and naive incompetence, and it was often difficult to tell which was which. |
03-22-2006, 10:54 PM
Post: #35
Whahaha hello there,
yep it was me,i did not reconize you :wink: I was'nt driving it to the max. I just picked it up at Jasper from Purmerend,so when you saw me it were my very first km. on the road And the timing had to be adjusted a little bit so i did not go over 6000 rpm. Monday Jasper adjusted the engine so now it rev's up as a muthaf#c$A And also the final gear is in now 4.556 This is the only trueno hatchback in the netherland at this moment. Coming weekend will be the first km's sideways |
03-22-2006, 11:11 PM
Post: #36
Damn. Now I don't have the nicest trueno of Holland anymore.
It is a very nice car. Very low... Have any pice which will show it a bit more, or do we have to wait for next weekend? 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
03-23-2006, 10:13 AM
Post: #37
It is indeed a very nice car...
I wanted to take some pics but i thought of that a bit to late What were you thinking when you saw me blinking the side markers ? WTF is that for idiot.. hahaha No no no noooooooooooooooooooo |
06-18-2007, 11:54 AM
Post: #38
Wow it has been a long time ago that i was here.
Let's try and update it Engine: 1600cc 20v Blacktop T3 Radiator Shroud T3 Velocity Stacks Pipercross Air Filters 200sx radiator With Extra Electric Cooling Fan Racing Light Weight Pulley Set Oil Catch Can Light Weight Flywheel 3,7 KG. TRD Spark Plug Cables FSE Power Boost Valve SpaanSpec Performance Exhaust Manifold + Heat Wrap TRD Oil Filter TRD Sport Thermostat Transmission: Clutch: TRD 3 Puck Final Gear: 4,778 Limited Slip Differential: TRD 2 WAY T3 Short Shifter Steel Braided Clutch Line Suspension: Yellow Koni Short Stroke SpaanSpec. Lowering Springs T3 Camber Plates T3 Negative RCA's T3 Tension Control Rods(caster adjustments) T3 Panhard Bar Largus D1 Spec Sway Bar Cusco Tension Rod F:3 point strut bar R:Strut Bar Rear 4 Link Set Rear Traction Brackets Brakes: Hydraulic Handbrake Brake Bias Controller Line Lock Steel Braided Brake Lines Interior: Fully Stripped & Lightened 2 Black Sparco Bucket Seats 2 Black Sparco 4 Point Sparco Racing Pedal Covers Sparco Driver Footrest Sparco Co Driver Footrest Sparco Shift Knob Sparco Fire Exthingisher T3 Spin Turn Knob(E-Brake) T3 Steering Adaptor 75mm Deep Dish Steering Wheel Tachometer + Shift Light Helmet Net Exterior: Black & Green Stickers With Blue Dragen Visracing Vented Carbon Fiber Hood Glasfiber Doors Glasfiber Rear Hatch Glasfiber Jubiride Spoiler Hood Rise Kit T3 Tow Hook Sparco Hood Pins Neon Kit(yea i know) One of my sponsors is Darren Mcnamara from http://www.mcnsport.com A well known corolla driver & parts specialist. |
06-18-2007, 05:16 PM
Post: #39
That's quite a list...you've been busy!
06-18-2007, 06:27 PM
Post: #40
Love the SpaanSpec parts!!
After taking a lift in that car in Zolder, the only thing I can say is: Crickey! What a sound! I reject your reality and substitute my own! No more Panda.. Tricolor bastard! If it 'aint broke, fix it 'til it is |
Scuderia rollator CE86 trueno project | NoHachi | 136 | 157,485 |
04-15-2013 05:53 PM Last Post: [Walaki]D`Lair |
Ae86 Levin drift project. | filip.alin | 7 | 9,747 |
my slow trueno project | cfly86 | 38 | 43,179 |
12-12-2012 04:35 AM Last Post: cfly86 |
My Drift project - 83' Trueno coupe | doggy | 158 | 273,914 |
10-23-2012 10:58 AM Last Post: Lightning |
My 20v booter project | diggerdolan | 2 | 5,456 |
10-01-2012 04:45 PM Last Post: zenki |
