please help!!! ( rear axle )
07-13-2010, 12:14 PM
I want to weld my diff but I can't pull the axle out. haw do I do it?
pls help me ...I have 1 week till next drift event!
http://s1.postimage.org/ac0kA.png
07-13-2010, 01:09 PM
download the body manual from the website and look into that. Think that is the most easy way.
07-13-2010, 09:14 PM
I'll tell you how.....
if you get rid of your video avatar thing or whatever it's called
Deal ? :wink:
07-14-2010, 09:01 AM
totta Crolla Wrote:I'll tell you how.....
Deal ? :wink:
done... Big Grin no more avatar
07-14-2010, 11:16 AM
i really need help ...anyone????
07-14-2010, 11:40 AM
I guess you mean you can't pull the halfshafts out of the housing? You either need to make a SST to fit on the halfshaft flange and hammer it out, or (at your own risk) hammer the flange directly out. The relevant toyota SST is shown in the repair manual, as does the procedure for rear axle overhaul if you go through it...
SFD
07-14-2010, 03:13 PM
You need a slide hammer puller.
[Image: AEU86 AE86 - please help!!! ( rear axle )]
Mine is this one, bought at machine mart
07-14-2010, 08:32 PM
Spawns... I feel real bad now Crying
Anyway I tried a slide hammer like the ones shown, no luck.
I bolted an old steel wheel onto to the hub and hit the back of it with a real big hammer. Once it had moved a fraction I sprayed some WD40 around the bearing and after soaking for a while the shaft came out fairly easily.
Take off the caliper complete with carrier, remove disc and remove the four bolts holding the bearing retainer in before any of the above though.
  AE86 rear axle weight megabob 11 19,138 03-29-2024 11:18 AM
Last Post: FanIsHere
  Axle width totta Crolla 1 1,169 10-24-2023 12:20 PM
  TUV RHD AE86 Germany (help please) 4dori 9 7,125 07-17-2019 07:42 PM
Last Post: Hachigo83
  Rear axle options Dino86 13 13,132 01-08-2018 10:19 PM
Last Post: ditn
  Carb question please help MIGGZFSU 3 4,761 03-29-2017 03:06 PM
Last Post: MIGGZFSU
