problem over 6000rpm
03-15-2011, 03:39 AM
hi everyone
i have a problem my 4age struggles to rev above 6000rpm -changed the fuel pump and still have the same problem -change plugs, the plugs cord have just a few months -coil ignitor working ok and use nother one to check -the engine timming is ok -fuel pressure is ok -have spark need help please I'm so JDM I put everything sideways. AE86 owner |
03-15-2011, 08:14 AM
If it runs fine below 6000 rpm and then just fades without popping or
banging, it is most likely timing. Either cam timing a tooth off, or ignition timing not set to 10 deg BTDC with engine in diagnostic mode. Cheers... jondee86 |
03-16-2011, 04:28 AM
ok my tvis is broken
i have this valve broken and the tvis just open when he wants ![]() anyone knows the part number icant find it on DIY I'm so JDM I put everything sideways. AE86 owner |
03-16-2011, 07:47 AM
Yup... that will do it !!! If the TVIS closes at high rpm, it will choke your
intake just like you backed off the throttle. If you disconnect the vacuum hose it should stay open all the time, and you can drive happy ![]() Cheers... jondee86 |
03-16-2011, 12:38 PM
yeah but the engine dont have power at lower revs if i do that
03-16-2011, 09:45 PM
Only a small loss of power... and better than driving with the butterflys
closed. You should be fine until you get the valve replaced (or check the wiring to see if it has got an intermittant short somewhere). Cheers... jondee86 |
03-17-2011, 02:40 AM
thanks mate
Over heating issues | MIGGZFSU | 12 | 12,356 |
05-11-2017 05:09 PM Last Post: MIGGZFSU |
Start wont turn over after installing radio | MC_JP | 6 | 10,092 |
09-22-2014 11:13 PM Last Post: izanagi |
4agZe problem solved - 99% IC problem | Okami | 41 | 37,686 |
07-12-2012 04:49 PM Last Post: Okami |
My AE86 Wont turn over | drunkenmunky115 | 8 | 8,165 |
04-20-2010 08:16 AM Last Post: drunkenmunky115 |
T3 FULL coil over system (front and rear), who is using them | 4000GT | 59 | 69,869 |
04-18-2010 05:58 PM Last Post: NoHachi |
