problem over 6000rpm
03-15-2011, 03:39 AM
hi everyone
i have a problem my 4age struggles to rev above 6000rpm
-changed the fuel pump and still have the same problem
-change plugs, the plugs cord have just a few months
-coil ignitor working ok and use nother one to check
-the engine timming is ok
-fuel pressure is ok
-have spark
need help please
AE86 owner
03-15-2011, 08:14 AM
If it runs fine below 6000 rpm and then just fades without popping or
banging, it is most likely timing. Either cam timing a tooth off, or ignition
timing not set to 10 deg BTDC with engine in diagnostic mode.
Cheers... jondee86
03-16-2011, 04:28 AM
ok my tvis is broken
i have this valve broken and the tvis just open when he wants
[Image: AEU86 AE86 - problem over 6000rpm]
anyone knows the part number icant find it on DIY
AE86 owner
03-16-2011, 07:47 AM
Yup... that will do it !!! If the TVIS closes at high rpm, it will choke your
intake just like you backed off the throttle. If you disconnect the vacuum
hose it should stay open all the time, and you can drive happy Smile
Cheers... jondee86
03-16-2011, 12:38 PM
yeah but the engine dont have power at lower revs if i do that
AE86 owner
03-16-2011, 09:45 PM
Only a small loss of power... and better than driving with the butterflys
closed. You should be fine until you get the valve replaced (or check the
wiring to see if it has got an intermittant short somewhere).
Cheers... jondee86
03-17-2011, 02:40 AM
thanks mate
AE86 owner
  Over heating issues MIGGZFSU 12 12,386 05-11-2017 05:09 PM
Last Post: MIGGZFSU
  Start wont turn over after installing radio MC_JP 6 10,102 09-22-2014 11:13 PM
Last Post: izanagi
  4agZe problem solved - 99% IC problem Okami 41 37,757 07-12-2012 04:49 PM
Last Post: Okami
  My AE86 Wont turn over drunkenmunky115 8 8,177 04-20-2010 08:16 AM
Last Post: drunkenmunky115
  T3 FULL coil over system (front and rear), who is using them 4000GT 59 70,117 04-18-2010 05:58 PM
Last Post: NoHachi
