rear axel swop
07-29-2008, 05:25 PM
rear axel swop
hey i broken my rear dif 2 times in less then 100km and i relley want to drive a littel moor in it i have a 250hp 4agze with turbo on it and som other mods i yost fittet a supre mk3 gear box and its a okey box but my problem is that i havent got a clue of what hear axel i can run on it have to have e 4,3 final og somthing bicors the supra .box is motch longer in gears and then it have to stand a violent beatingSmile pleas help mii i have to run sd-series on the 12 of orgust and it have to work..
ps the old dif and axel was zenki with kazz 2way and i kild both the diff and krown wheel on it
yhanks mikkel worholm. denemark
08-09-2008, 06:55 AM
rear axel swop
Toyota Hilux five stud with LSD. I don't know the tech specs on it,
but if you Google Hilux diff + AE86 + 4AGZE you will find a whole
bunch of information. It has been done many times here in NZ Smile
Cheers... jondee86
08-12-2008, 05:41 AM
rear axel swop
you can also fit an F series, slightly less overkill than the G, I think it's from a cressy. Search is your friend. This one has also been done many times in Oz.
08-12-2008, 05:47 AM
rear axel swop
Many people do the celica rear end in teh AE86 as well.
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
  Axel anyway to tell the difference? MIGGZFSU 7 8,550 10-24-2017 08:48 PM
Last Post: MIGGZFSU
  A60 Carina rear axel, AE86 parts nyberrg 3 6,912 09-02-2015 09:21 PM
  Rear ae86 rear discs & pad part numbers? J-86 4 6,425 11-30-2012 06:32 PM
Last Post: J-86
  GZE Swop with PAS & AC Lauren 12 14,964 02-16-2012 01:04 PM
Last Post: heshan
  Adjustable Rear trailing arm/rear 4 links? lolali 1 4,954 10-03-2009 05:17 PM
Last Post: lolali
