rear axle half sharft
09-26-2008, 05:03 PM
It is a slide hammer! Wink
Ben you can buy these from Machine Mart, Demon Tweeks, Halfords etc. Around £40.
The Machine Mart is heavy duty with a big weight.
If your axles arent rusted in place then you might be able to get it out another way.
Unbolt the outer dust seal, put the brake disc back onand bolt it down tight. Then using a dead blow mallet / rubber mallet strike the back face of the brake disc - rotate it 90 and smack it again, repeat all the way until the shaft comes out. If after a few attempts it hasnt come out get a slide hammer.
I did 1 shaft like this (came out easy) the other one took about 10 mins of serious slide hammer action before it popped out.
Once out, use some fine wet and dry to clean off any surface rust on the bearing outer race and also clean up the inner section of the axle.
[Image: AEU86 AE86 - rear axle half sharft]
http://www.eight-six.co.uk - read the blog!
UK AE86 Forum - http://www.phpbber.com/phpbb/index.php?m...ghtsixcouk
09-26-2008, 05:11 PM
thank you very much man.
other request is anyone got a late shaft for sale ? save my time if can find one in UK.
09-27-2008, 02:02 AM
thx
yes this project gonna take me a while and im thinkin to start the next saturday
i dont like the rust so i m gonna take off all the rust of the front
  AE86 rear axle weight megabob 11 19,132 03-29-2024 11:18 AM
Last Post: FanIsHere
  Axle width totta Crolla 1 1,166 10-24-2023 12:20 PM
  Half Shafts Poblem AlexKTM 6 6,856 04-23-2018 04:42 PM
Last Post: MIGGZFSU
  Rear axle options Dino86 13 13,127 01-08-2018 10:19 PM
Last Post: ditn
  Rebuild rear disc brakes toyota crown ms112 axle bozu 0 3,836 12-21-2016 09:37 PM
Last Post: bozu
