ring gear bolts
12-24-2016, 06:17 PM
ring gear bolts
building the axle right now. can i reuse the ring gear bolts? if not, which bolts do i need to buy?
[Image: AEU86 AE86 - ring gear bolts]
12-24-2016, 10:22 PM
ring gear bolts
I have re-used them without issue, you might want to use new locking tabs though.
12-25-2016, 02:32 PM
ring gear bolts
thanks, with the kaaz diff i cant use the locking tabs. do you think i can use a little loctite?
12-26-2016, 10:56 PM
ring gear bolts
Yes genuine Loctite will work. Check the application as there are different grades of Loctite.
  5th gear issue r.ave 1 2,766 03-14-2021 08:52 PM
  Head bolts: You decide..... oldeskewltoy 8 10,664 11-11-2020 06:33 PM
Last Post: oldeskewltoy
  T50 gearbox - TRD 2nd and 3rd gear hachirokkos 3 6,920 11-27-2015 10:06 AM
Last Post: Project D
  torque setting head cylinder bolts izanagi 1 5,107 05-29-2015 01:23 AM
  Decently heavy vibration in fourth gear between 2000-2300rpm dinkers542 4 5,791 11-29-2014 12:27 AM
Last Post: dinkers542
User(s) browsing this thread:
