rough run/stall 4a-ge
03-26-2012, 04:22 AM
need a bit of help. 4age turbo has a rough run. Won't idle above 1100ish on warm-up. Sounds like its gunna stall at times and a little bit of oily water out the tailpipe. Any idea's? Thanks everyone!!!
EDIT: turbo manifold and exhaust also leak like a bastard if that makes a difference. Also noticed that after the car is warmed up it will stall at idle. I could be just driving around normal, push the clutch and the rpms will drop till it stalls out.... or just at a stop light on idle. Starts right back up tho. Any help is awesome! |
03-27-2012, 05:04 AM
bump, anyone? Please
03-27-2012, 03:57 PM
fix all leaks first and if problem persist we can look further
![]() AE86 ex-daily |
Where to run the factory antenna cable | andyling | 2 | 3,934 |
09-30-2020 12:31 PM Last Post: andyling |
Machining Pistons to run 20v head... And FCR's on a 20v? | PazzaAE86 | 2 | 5,279 |
09-15-2013 01:08 AM Last Post: jondee86 |
Rough starts | desertdriftAE86 | 5 | 5,395 |
03-01-2012 07:24 AM Last Post: desertdriftAE86 |
E/G stall after Right hand corner | Dino86 | 10 | 12,022 |
03-27-2011 01:55 PM Last Post: Dino86 |
o2 sensor and rough idling | alex-evo | 8 | 6,770 |
11-26-2008 08:08 PM Last Post: alex-evo |
