Rough starts
02-28-2012, 09:32 AM
Rough starts
Ok guys im having a problem with cold starts, when the motor is cold and i fire her up it idles rough and turns off if im not giving it gas. once it reaches good temp the motor idles alright, maybe cuz of the cams it idles weird. but the cold starts are killing me... what can the issue be? where should i start...
02-28-2012, 11:48 AM
Rough starts
Sounds like your thermostatic idle-up valve under the throttlebody is
either stuck/failed closed, or maybe it has been deleted. Either way, it seems you are not getting any extra air bled into the intake manifold to raise the cold idle. Do you still have two small rubber hoses taking water to the valve, and do they get hot when the engine is warmed up ?? Cheers... jondee86 |
02-28-2012, 04:50 PM
Rough starts
as above, for normal engine, but you mention cams, what spec?? And tuning/ecu?
03-01-2012, 07:23 AM
Rough starts
sorry took a while to reply... i really dont know much bout the car, my friend owe me money and he gave me the car. so ima look at it tomorrow morning and check out.
03-01-2012, 07:24 AM
Rough starts
and tuning doesnt seem that its been tuned, i havent checked if its a stock ecu yet. theres much to learn bout this ride.
Engine starts/revs but no idle | GenkiMotors | 17 | 8,084 |
11-20-2021 04:12 AM Last Post: GenkiMotors |
AE86 4age engine not starts crank ok backfires to air intake | Ryo | 18 | 18,151 |
08-16-2018 01:36 AM Last Post: Bean |
Bad vibrations /resonance starts at 5000 rpm | izanagi | 7 | 8,737 |
07-23-2015 05:02 PM Last Post: Bean |
Engine cranks slowly when hot... but starts | Dino86 | 9 | 14,513 |
02-03-2014 08:04 PM Last Post: Dino86 |
rough run/stall 4a-ge | purplerain11 | 3 | 4,691 |
03-27-2012 03:57 PM Last Post: Bean |
