Rough starts
02-28-2012, 09:32 AM
Rough starts
Ok guys im having a problem with cold starts, when the motor is cold and i fire her up it idles rough and turns off if im not giving it gas. once it reaches good temp the motor idles alright, maybe cuz of the cams it idles weird. but the cold starts are killing me... what can the issue be? where should i start...
02-28-2012, 11:48 AM
Rough starts
Sounds like your thermostatic idle-up valve under the throttlebody is
either stuck/failed closed, or maybe it has been deleted. Either way, it
seems you are not getting any extra air bled into the intake manifold
to raise the cold idle.
Do you still have two small rubber hoses taking water to the valve, and
do they get hot when the engine is warmed up ??
Cheers... jondee86
02-28-2012, 04:50 PM
Rough starts
as above, for normal engine, but you mention cams, what spec?? And tuning/ecu?
03-01-2012, 07:23 AM
Rough starts
sorry took a while to reply... i really dont know much bout the car, my friend owe me money and he gave me the car. so ima look at it tomorrow morning and check out.
03-01-2012, 07:24 AM
Rough starts
and tuning doesnt seem that its been tuned, i havent checked if its a stock ecu yet. theres much to learn bout this ride.
  Engine starts/revs but no idle GenkiMotors 17 7,321 11-20-2021 04:12 AM
Last Post: GenkiMotors
  AE86 4age engine not starts crank ok backfires to air intake Ryo 18 17,275 08-16-2018 01:36 AM
  Bad vibrations /resonance starts at 5000 rpm izanagi 7 8,285 07-23-2015 05:02 PM
  Engine cranks slowly when hot... but starts Dino86 9 13,627 02-03-2014 08:04 PM
Last Post: Dino86
  rough run/stall 4a-ge purplerain11 3 4,483 03-27-2012 03:57 PM
