shaking
04-05-2009, 09:20 PM
shaking
hi
My car is shaking when i pull away slowly in 1st and reverse, its recently(4 month) had a clutch fitted, not had many miles put on it since then as the car is only really used every other weekend.
thanks
hopper.
04-06-2009, 09:13 AM
shaking
So, clutch fully engaged, engine revs low (<1000 rpm) and car moving
slowly.... right ??
Did this start right from the time the clutch was changed, or did it work
fine to begin with, and then start shaking ??
Any other noise or vibration at higher revs ??
Cheers... jondee86
04-06-2009, 10:22 AM
shaking
Did you have a standard Toyota clutch fitted or an uprated one ?
04-06-2009, 06:11 PM
shaking
the clutch is a standard one, it does vibrate at around 5.5-6k plus as well, the shaking starts as soon as the clutch is engaged, you can really feel it through the gear stick. i think it did it before the clutch got changed, interestingly it doesn't shake when the car is completly cold.
thanks
andrew
04-06-2009, 09:21 PM
shaking
The revs will be higher when the engine is cold.
It may be worth checking the engine and gearbox mounts.
04-07-2009, 09:39 AM
shaking
If it doesn't shake when the box is in neutral or with the clutch depressed,
it is pretty safe to say that it is not due to any out of balance in the clutch.
And since you describe it as "shaking" and not "vibrating", I would assume
this is a low frequency thing. Perhaps you have one weak cylinder ? If you
have a cylinder that is down on compression, it does not generate the
same amount of torque as the other three, and is felt as a cyclic pulse at
low engine speeds. At higher speeds the performance of the weak
cylinder improves, as there is not so much time for compression to leak
away.
Homegrown theory Tongue Might be worth doing a compression test tho Smile
Cheers... jondee86
04-09-2009, 05:14 PM
shaking
cheers, i'll check the engine and gar box mount and do a compression test, then report back.
thanks
Hopper
  [Help] Steering Wheel shaking !! Kyosuke 9 11,009 12-13-2006 10:48 AM
Last Post: mrgud
