stand alone ECU but i want to keep my rev clock
06-30-2010, 09:35 AM
irishtwincam Wrote:[Image: AEU86 AE86 - stand alone ECU but i want ... rev clock]
Use these diodes on a twin coil pack setup and your stock AE86 tacho will work fine!
Big thanks to PhatBob for this info by way of the VEMS project.
Coil 1 and 2 refer to twincoil negative signal wires.
Will this work when im runing an Omex600 ECU. As you know the Omex has a tacho wire but it wont work my standard rev clock Banging head
Drive it like your late for mass and god is your passenger / don’t just bend the rules rule the bends fun ant in a straights!!
06-30-2010, 05:30 PM
williep12
You have to tell us what ignition you are going to run. If you keep the distributor you don't need to do anything.
With twin coils do what IrishTC says.
Coil on plugs is harder since you have to run it from your ECU...
06-30-2010, 07:31 PM
Or you build yourself a tach booster and just use the ecu's output.
I can make one for you if you cant do it yourself... it's pretty easy.
06-30-2010, 09:57 PM
Sure but why?
I have to build one, though Smile
06-30-2010, 10:19 PM
Jan Pedersen Wrote:williep12
Ye sorry Dumb question im runing a coil pack out of a 00 Saxo twin spark.
im no good at the wiring thing lads Banging head
Dont know if ye say it but this is my engine you can see the coil pack to the right sideThumbs up!
http://youtube.com/watch?v=tzdJ6X9iDoo
06-30-2010, 10:25 PM
A couple of diodes will do the trick to, but I don't really like the idea of 'connecting' these otherwise independent signal lines together.
Using the ECU output keeps things nice and clean, no nasty electrical gremlins in the ignition should a diode fail.
07-13-2010, 03:39 PM
Ivan141 Wrote:Or you build yourself a tach booster and just use the ecu's output.
Hi
Can you make me up one please and ill cover the cost Respect!
07-17-2010, 12:11 AM
I'll see what I can rustle up...
08-25-2010, 02:26 PM
Ivan141, Your desk does look like mine!!! Smile
  Engine starts/revs but no idle GenkiMotors 17 8,080 11-20-2021 04:12 AM
Last Post: GenkiMotors
  Carb conversion but what is this and how ? Allexz 5 8,763 05-24-2016 08:48 AM
Last Post: Allexz
  Raising the rev limit on stock ECU fax0815 2 11,196 08-31-2015 02:04 PM
Last Post: gon
  4age 16v oem ecu rev limiter research ditn 18 29,175 06-22-2015 08:02 AM
Last Post: ditn
  getting new sparkplugs, or keep away ? MC_JP 5 6,499 09-19-2014 11:35 PM
Last Post: Project D
