stand alone ECU but i want to keep my rev clock
06-30-2010, 09:35 AM
irishtwincam Wrote: Will this work when im runing an Omex600 ECU. As you know the Omex has a tacho wire but it wont work my standard rev clock ![]() Drive it like your late for mass and god is your passenger / don’t just bend the rules rule the bends fun ant in a straights!! |
06-30-2010, 05:30 PM
williep12
You have to tell us what ignition you are going to run. If you keep the distributor you don't need to do anything. With twin coils do what IrishTC says. Coil on plugs is harder since you have to run it from your ECU... Sarcasme is just one of the things I offer ![]() Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch ![]() |
06-30-2010, 07:31 PM
Or you build yourself a tach booster and just use the ecu's output.
I can make one for you if you cant do it yourself... it's pretty easy. FABRICA MI DIEM, PVNC! |
06-30-2010, 09:57 PM
Sure but why?
I have to build one, though ![]() Sarcasme is just one of the things I offer ![]() Daily driver: '92 Toyota Carina E GTI Rebuilt project: '86 Levin hatch ![]() |
06-30-2010, 10:19 PM
Jan Pedersen Wrote:williep12Ye sorry ![]() im no good at the wiring thing lads ![]() Dont know if ye say it but this is my engine you can see the coil pack to the right side ![]() http://youtube.com/watch?v=tzdJ6X9iDoo Drive it like your late for mass and god is your passenger / don’t just bend the rules rule the bends fun ant in a straights!! |
06-30-2010, 10:25 PM
A couple of diodes will do the trick to, but I don't really like the idea of 'connecting' these otherwise independent signal lines together.
Using the ECU output keeps things nice and clean, no nasty electrical gremlins in the ignition should a diode fail. FABRICA MI DIEM, PVNC! |
07-13-2010, 03:39 PM
Ivan141 Wrote:Or you build yourself a tach booster and just use the ecu's output. Hi Can you make me up one please and ill cover the cost ![]() Drive it like your late for mass and god is your passenger / don’t just bend the rules rule the bends fun ant in a straights!! |
07-17-2010, 12:11 AM
I'll see what I can rustle up...
08-25-2010, 02:26 PM
Ivan141, Your desk does look like mine!!!
Engine starts/revs but no idle | GenkiMotors | 17 | 8,256 |
Carb conversion but what is this and how ? | Allexz | 5 | 8,798 |
05-24-2016 08:48 AM Last Post: Allexz |
Raising the rev limit on stock ECU | fax0815 | 2 | 11,279 |
08-31-2015 02:04 PM Last Post: gon |
4age 16v oem ecu rev limiter research | ditn | 18 | 29,381 |
06-22-2015 08:02 AM Last Post: ditn |
getting new sparkplugs, or keep away ? | MC_JP | 5 | 6,543 |
09-19-2014 11:35 PM Last Post: Project D |
User(s) browsing this thread:
