starting/electrical issues
12-11-2013, 09:21 AM
Jezza_hr Wrote:I have been having an intermittent starting issue... There is nothing intermittent about wire size/gauge! There is often something intermittent about bad connectors/terminals/crimps and their contact! This includes battery terminals!!!!!! Feel all the cabling & connectors, if its hot it's telling you that it is either undersize or has resistance from bad contact. |
12-11-2013, 11:19 AM
jondee86 Wrote:To be fair, throwing bigger cable at it is not the best way to solve this I'll check the resistance through both connections. I've ordered up a Digital voltage meter, since the analogue one I have is a pain to read. The only other idea I have had, is if the 4G wire is the culprit, is to create a bigger ground at the back of the car and double up on the 4G wire to the positive terminal to reduce the overall resistance. Not the neatest way to do it, but if it works it shows that investing in 0 gauge isn't such a bad idea. |
12-14-2013, 02:37 PM
Okay, I've had an opportunity to check this today.
When going out to look at the readings across everything the battery was reading as little as 11.3v, which is a little low. I decided to test the voltage at the junction box and at the starter. The readings were a little odd, since they were .1v higher than the battery itself ![]() I attempted to start the car and as I expected it was reluctant to get the starter motor running, so I had to swap for my fresh battery reading 12.6v from the garage. Whilst I had the old battery out, I decided to do some changes by creating a new ground from the block with a nice clean connection to bare metal on the chassis and I doubled up on my 4 gauge wire to reduce any resistance that may be found at the junction box. I also decided to re-solder some ignition wires in the off chance these could be causing an issue. When I put in the battery it sprung to life quicker than it ever has done before, I'm thinking the change in ground and doubling up the wire may have helped with this. Reading the battery whilst the ignition was on, I could see it was getting a steady 14.4v, but would drop down to the region of 13.5v with all the lights on, stereo, blower etc. but when revving up to 1500 rpm, it all leveled out to 14.4v again. I thought everything seemed fine, but to check any other irregularities, I wanted to check that nothing is draining the battery while the car isn't in use. I understand that 0.2 mah is the most you want to see being drained from your battery, however mine measured at 0.1 mah so, I don't think there's an issue here. I'm hoping that my tinkering around has sorted my issues, I'll soon find out I guess if the problem occurs again. When I can next get behind the dash, I will be swapping the power lead for the tachometer though, as there still seems to be the odd bit of movement when using things such as the indicators, so I may route this to a constant 12v feed instead of an ignition feed. |
12-15-2013, 02:03 AM
All starters love a fully charged battery
![]() had a high resistance ground. Testing voltages with the engine running or off lets you know that you have continuity. But to test the performance of the circuit, you need to do a voltage drop test. In the case of problems with the starter, you need to check what the voltage drops to while the starter is cranking i.e. with max current flowing in the starter circuit. Test between the starter positive and ground.... ![]() This will tell you the voltage that is being applied to the starter during cranking. You should be looking for a minimum of 10 - 11V and if it is low (say 5 or 6V), then you need to check the voltage drop in the starter supply circuit... ![]() ... and in the ground return circuit while cranking. ![]() Ideally, you are looking for a voltage drop of not more than 0.25 - 0.5V in these circuits... lower is better. Not trying to be a smarta$$ as all this information is readily available on the interweb, and you have already solved your problem. But there may be others who will find the diagrams helpful when they are trouble shooting their own starting problems. Cheers... jondee86 |
12-21-2013, 05:45 PM
This eternaly 4age 16v problem...the starter
![]() Once upon a time i have metalic hose on the back seat and when the starter not cranking then i was kicking her ass with hose ![]() Jondee has right for the volts....mine had problem it was 6v when try to crank the engine....i replace some cables and the contacts, i relocate the starter on the intake side, get a rebuild 4afe starter , my electrician made some kind of ampilifier to help the starter with a relay... and finally i use lightweight flywheel from the blacktop. I have ae92 4age16v. the Starter problem dissapeared for ever, now i that the starter will never stuck again,i feel that she has more power .... ![]() 4age 16v to FR 20VT |
Running issues | sam3007 | 6 | 3,131 |
lntermittent starting | totta Crolla | 6 | 3,909 |
Starting problems 4-AGE kouki | Hanzo | 3 | 2,835 |
Over heating issues | MIGGZFSU | 12 | 12,338 |
05-11-2017 05:09 PM Last Post: MIGGZFSU |
JDM trueno not starting. need help! | kazi | 8 | 9,243 |
User(s) browsing this thread:
