trans wont shift into 3rd or 4th :(
04-13-2008, 06:48 AM
hey guys first things first im pretty new, and actualy my car isent a AE-86 (unfortunately) its an AE-92 fwd, but i cant find any forums for my car, and i fugure we share the same motor, so why not ask you guys for help.
i just got my car running again (with your guyses help) it had been sitting for a lil while maybe a month or so. when i got it to run it was doing fine, shifting perfectly and everything was ok. but out of nowhere with out any warning signs, as im driving along my car just stops shifting into 3rd and 4th gear. it was just fine befor, never slipped or ANYTHING it will "click" into 3rd but as soon as i pop the clutch it shoots out of gear and if i try to force it in, it just makes a horrable grinding sound. and it wont even go into 4th at all, its like 4th isent there anymore. 1st 2nd 5th and reverse work fine. I checked the oil, all good and brand new. HELP! thank you |
04-13-2008, 09:52 AM
Sounds like you broke one of the gear selector forks
Cheers... jondee86 |
04-14-2008, 12:40 AM
any idea to how u think this happend? what would you say i do to fix it?
04-14-2008, 12:58 AM
the box will need stripping down,or replacing
04-14-2008, 01:05 AM
thanks guys. ima go take a look at it.
is there anything else that it might possably be? Beater cars, they run fine.........till you need to use them |
04-14-2008, 10:20 AM
when was the last time it had a trans service?
04-14-2008, 12:12 PM
Before you pull the box out, check the linkage from the gearlever to the box. Something may have moved slightly.
I'm not familiar with the AE92 gearbox setup, but I had a similar problem on the wife's Fiesta, a few years ago. It just needed a slight adjustment at the gearbox end, and all was well again. http://www.AE86imports.0catch.com |
04-14-2008, 10:30 PM
i've never had it "serviced" but i have changed the trans fluid. i did that about a month ago.
i'll take a look at the linkage. Beater cars, they run fine.........till you need to use them |
04-14-2008, 11:28 PM
odeaten Wrote:i've never had it "serviced" but i have changed the trans fluid. i did that about a month ago. What oil did you use? 5/2018 BMW F22 Coupe 1/1985 Toyota AE86 Levin Coupe |
04-15-2008, 08:33 AM
just plain tranny fluid. i dont remember what brand or nothin.
i checked the linkage and it aint the problem. Beater cars, they run fine.........till you need to use them |
Can you seperate trueno kouki bumper lights into zenki bumper lights? | gh0st | 17 | 8,240 |
12-19-2021 11:58 PM Last Post: gh0st |
Shifting from 4th to 3rd | pack | 7 | 6,357 |
04-27-2017 07:26 PM Last Post: totta Crolla |
T50 gearbox - TRD 2nd and 3rd gear | hachirokkos | 3 | 6,709 |
11-27-2015 10:06 AM Last Post: Project D |
trans oil, lsd oil change | Apolan | 9 | 17,158 |
Whining noise only in 4th & 5th. | izanagi | 7 | 10,710 |
09-25-2014 07:09 PM Last Post: Uzelac |
