trans wont shift into 3rd or 4th :(
04-13-2008, 06:48 AM
hey guys first things first im pretty new, and actualy my car isent a AE-86 (unfortunately) its an AE-92 fwd, but i cant find any forums for my car, and i fugure we share the same motor, so why not ask you guys for help.
i just got my car running again (with your guyses help) it had been sitting for a lil while maybe a month or so. when i got it to run it was doing fine, shifting perfectly and everything was ok. but out of nowhere with out any warning signs, as im driving along my car just stops shifting into 3rd and 4th gear. it was just fine befor, never slipped or ANYTHING Undecided
it will "click" into 3rd but as soon as i pop the clutch it shoots out of gear and if i try to force it in, it just makes a horrable grinding sound. and it wont even go into 4th at all, its like 4th isent there anymore. 1st 2nd 5th and reverse work fine.
I checked the oil, all good and brand new.
HELP! Sad Sad thank you
04-13-2008, 09:52 AM
Sounds like you broke one of the gear selector forks Undecided
Cheers... jondee86
04-14-2008, 12:40 AM
any idea to how u think this happend? what would you say i do to fix it?
04-14-2008, 12:58 AM
the box will need stripping down,or replacing
[Image: AEU86 AE86 - trans wont shift into 3rd or 4th :(]
04-14-2008, 01:05 AM
thanks guys. ima go take a look at it. Respect!
is there anything else that it might possably be?
Beater cars, they run fine.........till you need to use them
04-14-2008, 10:20 AM
when was the last time it had a trans service?
04-14-2008, 12:12 PM
Before you pull the box out, check the linkage from the gearlever to the box. Something may have moved slightly.
I'm not familiar with the AE92 gearbox setup, but I had a similar problem on the wife's Fiesta, a few years ago.
It just needed a slight adjustment at the gearbox end, and all was well again.
http://www.AE86imports.0catch.com
04-14-2008, 10:30 PM
i've never had it "serviced" but i have changed the trans fluid. i did that about a month ago.
i'll take a look at the linkage.
04-14-2008, 11:28 PM
odeaten Wrote:i've never had it "serviced" but i have changed the trans fluid. i did that about a month ago.
What oil did you use?
04-15-2008, 08:33 AM
just plain tranny fluid. i dont remember what brand or nothin.
i checked the linkage and it aint the problem. Undecided
  Can you seperate trueno kouki bumper lights into zenki bumper lights? gh0st 17 8,027 12-19-2021 11:58 PM
Last Post: gh0st
  Shifting from 4th to 3rd pack 7 6,302 04-27-2017 07:26 PM
Last Post: totta Crolla
  T50 gearbox - TRD 2nd and 3rd gear hachirokkos 3 6,663 11-27-2015 10:06 AM
Last Post: Project D
  trans oil, lsd oil change Apolan 9 17,070 10-01-2014 03:57 PM
  Whining noise only in 4th & 5th. izanagi 7 10,646 09-25-2014 07:09 PM
Last Post: Uzelac
