webber carbs continued
07-10-2010, 02:10 AM
so i took the advice on the regulator...it did bring the pressure down but for some resaon now the car wont start...i have spark and the engine turns plus the fuel pump is working...maybe i messed up the timing changing the front cam seals?....i turned the crank pulley's timing mark to zero and turned both cams to thier apropriate timing marks( top dead center) and then i set the distributor timing as well...i hope the problem lies with the timing...all electrical components are fine...one more thing fuel was spraying out of a littile hole on the back of the webber carbs as i tried to start the engine...dont know what this means
p.s. sorry i posted as a new topic...i meant to continue the old thread
Webber 40 on stock 4AGE | Spitfire | 1 | 4,610 |
12-02-2015 11:30 PM Last Post: totta Crolla |
Type of carbs to suit 4ag | kpretro84 | 23 | 25,615 |
02-09-2013 02:29 AM Last Post: bakonick |
TPS for carbs | totta Crolla | 7 | 7,873 |
01-30-2013 09:14 PM Last Post: totta Crolla |
need expirienced ae86 owners..webber carbs help..frustrated | joon900 | 4 | 8,043 |
06-25-2010 01:21 PM Last Post: eight-six |
igniter wiring for carbs | nikos_trd | 3 | 4,819 |
08-24-2009 09:50 PM Last Post: nikos_trd |
