weird problem...
06-29-2006, 11:43 PM
weird problem...
I have a weird problem with my hachi. Every time i drive it , a smoke film appears in the 3rd door glass surface mainly, and after a while this "film" appears in all glass surfaces of my car.
It is really annoying... I dont have an idea where it comes from ( it looks like oil when light hits it ) Any ideas?? What can i do to stop it?? As i said it is really annoying |
06-30-2006, 12:13 AM
weird problem...
That has to be the weirdest problem I have ever heard if it's really like oil...then again you are greek...ever heard of condensation (just kidding offcourse :wink: ). Does it go away when you switch on the window heating? Have you tried cleaning the windows already?
06-30-2006, 12:55 AM
weird problem...
Ofcourse i have cleaned the windows!!
And the film appears all the time even with the windows open.It is not like in winter, when windows dazzle with breath. I havent seen any other hachi doing that, only mine |
06-30-2006, 09:13 AM
weird problem...
To reduce such effects clean the windows inside with ethyl alcohol.
06-30-2006, 10:27 AM
weird problem...
Could also be that your heater matrix is leaking coolant and releasing glycol fume to the inside of the car through the vents. Gycol tends to create an oily film on the inside of the windows and trying to wipe if off just smudges it around somewhat. Even a very small leak not easily visible when checking the coolant level on the radiator may cause this.
One way to diagnose this would be to override the heater matrix as whole, rerouting the coolant directly from one hose to another in the engine bay but those hoses are in a rather awkward place on the firewall behind the intake manifold. |
06-30-2006, 10:34 AM
weird problem...
That film, what exactly is it?
It sounds like a porno film... Or is it adventure? danielvanderwoude Wrote:looks like the nmwisima joke saved you in the endhttp://www.jdmbits.com |
06-30-2006, 08:58 PM
weird problem...
nmwisima Wrote:That film, what exactly is it?For you it would, knowing you're a petrolhead. Some people clean their windows with pure dishsoap to prevent condensation which also leaves a thin film when condensating, but then again you cleaned them and it came back. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
weird gearbox part2(possible trd set a) | ditn | 6 | 7,117 |
01-31-2016 08:01 PM Last Post: totta Crolla |
T50 weird gear set What´s going on? | fax0815 | 13 | 44,741 |
08-13-2012 04:50 PM Last Post: Project D |
4agZe problem solved - 99% IC problem | Okami | 41 | 36,218 |
Oil Pressure - Kinda weird | pack | 12 | 21,118 |
05-31-2012 12:56 AM Last Post: pack |
Weird issue with hydraulics on the clutch | Lauren | 4 | 5,601 |
09-03-2011 05:16 AM Last Post: bozu |
