what bearings for my build?
09-22-2012, 11:24 AM
Hello everyone,
I'd like o get some input/experiences regarding bearings for mains and rods for my engine build. I'm using a 40mm crank so less options available ![]() So far I considered TRD and ACL Race for the Mains (100$-130$) and TRD for the rods. My engine will rev up to 8-9k and 170-200hp @fly. Thanks for reading and looking forward to your experiences. PS: also opinions about the 'perfect' clearance/tolerance for the bearings would be interesting. Car is not an all out racer so still used on the street for a run down to the shops etc... AE86 ex-daily |
09-22-2012, 03:41 PM
You also have Clevite (Mahle) available in 40mm
09-22-2012, 03:46 PM
Project D Wrote:You also have Clevite (Mahle) available in 40mm There are quite a few other brands (clevite, F1 Black, OEM Toyota, etc). I'm looking for experience people had with any and how they lasted etc... As I don't plan to drop the sump every 6 months to check if everything is still in one piece. AE86 ex-daily |
09-22-2012, 04:53 PM
I'm running clevite if that helps...........
Oh... btw... you DON'T want to spin that crank much above 8400.... the early cranks are lighter... by almost a kilo... but because SOME of the counter weights are different, the crank can have issues above the mid 8000s Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
09-22-2012, 05:12 PM
oldeskewltoy Wrote:I'm running clevite if that helps........... The crank will be worked to prevent this. I won't take it beyond 7k in this country anyway. How much were the Clevite and are they available in different sizes? ACL only has 2 sizes. TRD 2 seizes for rod-end and 6 for mains. And so on... AE86 ex-daily |
09-22-2012, 10:25 PM
Bean Bandit Wrote:oldeskewltoy Wrote:I'm running clevite if that helps........... Sorry... can't tell you that, I didn't do the bottom end, Loynings did.... Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
7AGE Build | apardal | 5 | 1,336 |
08-02-2024 12:11 PM Last Post: apardal |
Question on Rod Bearings | mister86 | 3 | 4,293 |
03-19-2020 03:46 AM Last Post: oldeskewltoy |
Emergency help find store with bearings france | Allexz | 5 | 5,064 |
09-12-2019 03:24 PM Last Post: Allexz |
Build your own adjustable fuel pressure regulator ;) | oldeskewltoy | 8 | 21,761 |
Diff bearings | izanagi | 11 | 16,624 |
07-05-2014 07:29 PM Last Post: assassin10000 |
