what clutch for a W58 trans to a 4AGE Blacktop?
07-02-2011, 06:32 PM
i have bought a W58 transmision some time ago and i have a 4AGE Blacktop.
i have a bellhouse to conect to the engine. but i do not know what for clutch i need for this. can some one help me. parts and part numbers, original or after market. sorry for my bad englisch toyota corolla coupe 1985 drift car toyota corolla coupe 1987 road car. |
07-03-2011, 07:33 AM
use any 18r clutch disc or sa63 celica as long as the clutch disc isnt bigger than your flywheel or you can just change the center to the bigger splines on your clutch disc
07-05-2011, 02:26 PM
I had a clutch made up with the Supra W58 centre splines on a 212mm AW11 Mr2 disc and fitted the 21mm MR2 flywheel, a blacktop may already have this fitted.
07-21-2011, 07:02 PM
can some one help me with a clutch for a W58 transmision?
11-09-2011, 12:00 PM
Solved ?
Unfortunately can't help, but interested how W58 goes behind 4AGE |
11-09-2011, 01:47 PM
I have an 1,8l diesel engine (1C) from an 1986 RWD CE70 wagon. this engine has W51 gearbox and 215mm clutch disc. so probably this clutch disc can be good for the 212mm blacktop flywheel and hopefully the input shaft diameter is also the same on the w51 and w58 gearboxes.
If I'll have a little time I'll check some sizes for you. |
11-09-2011, 05:51 PM
Hello Pal
You need to use A. 4age Flywheel B. 4age Pressure Plate C. w58 Throwout Bearing The center spindle of the w58 is a 21 teeth 1 1/8 The Center spindle of the stock t50 is 21 teeth 15/16 D. You need someone that can fabricate a clutch for you using the center section of the w58 clutch disc with the Outer Diameter of the 4ag disc. I know ACT can help you ask for a sprung- Custom Disc worksheet so you can write your needs and send them. They can fabricate one for you. Or you can ask local clutch specialist for one. |
11-10-2011, 01:37 PM
NIce.
Is this the same for all 4AGE, both 16V and 20V ? |
11-10-2011, 04:42 PM
Uzelac Wrote:NIce. |
11-11-2011, 05:42 PM
thanks. that will help.
stock injector deadtime for 4age 20v silvertop/blacktop injector | ditn | 1 | 5,938 |
02-20-2016 11:48 AM Last Post: Bean |
trans oil, lsd oil change | Apolan | 9 | 17,216 |
7AGE to W58, cluth type? | slowboy2 | 3 | 5,561 |
05-25-2013 01:37 PM Last Post: slowboy2 |
Collecting info for w58 conversion | ditn | 1 | 4,888 |
06-01-2012 08:59 PM Last Post: ditn |
Exedy 'S New Metal' Racing Clutch Kit Toyota 4AGE AE86, | dsrturbo | 2 | 5,932 |
07-28-2011 10:51 AM Last Post: Bean |
