what clutch for a W58 trans to a 4AGE Blacktop?
11-11-2011, 08:05 PM
If you don't want custom one, you can buy 1987 CE70 1,8 Diesel RWD clutch. I compared and checked it today, it fits perfect on W5X gearbox and exactly the same diameter as the one from blacktop. I will use it on my 4ag to W55 gearbox conversion.
11-16-2011, 03:02 PM
What diff and axle do you plan to use ?
Can standard axle with some aftermarket diff (TRD, KAAZ...) handle ~200 hp which good 4AGE can produce ? |
11-16-2011, 05:34 PM
I am using this setup
In the past I had a 20v silvertop turbocharged, gts welded rear aprox 230 to the wheels with no problem on diff or transmission. now I switched to NA silvertop and trd lsd. the axles are ok and the transmission has no shift problems I drive the car hard but no drifting on stunt crazy driving. After a couple of years I understood that balance is everything and fuel economy was priority, I pulled the turbo and bought an LSD Change your diff oil regularly |
11-16-2011, 05:54 PM
Great, i knew W5x can handle that hp, but wasn't sure about diff.
I found W58 and now considering to swap T50 to W58. My T50 is managing ~140hp pretty well, not sure if it will handle next power bump (hoping for 170+) but thinking it could. So, the question is, is swaping to W58 worth if you consider only gear ratios. As i see it 1st is a bit longer, 5th is much better for crusin but shift points in between are pretty much the same. Is it worth trouble to switch to w58 just because of that ? Thanks p.s. What type of hard driving is your AE86 coping with ? Track or street ? Rally ? |
11-16-2011, 07:43 PM
Uzelac Wrote:Great, i knew W5x can handle that hp, but wasn't sure about diff. daily driving up to 7500 rpm and track driving ( not to often ) your clutch will be the weakest point |
11-16-2011, 09:32 PM
Can a 4AGZE or 20v flywheel e fitted on blue 16v?
11-17-2011, 08:36 PM
i have a complete flywheel and clutch from a supra non turbo. this fit the blacktop engine and the w58 gearbox.
thanks for all your help. toyota corolla coupe 1985 drift car toyota corolla coupe 1987 road car. |
stock injector deadtime for 4age 20v silvertop/blacktop injector | ditn | 1 | 5,895 |
02-20-2016 11:48 AM Last Post: Bean |
trans oil, lsd oil change | Apolan | 9 | 17,101 |
7AGE to W58, cluth type? | slowboy2 | 3 | 5,519 |
05-25-2013 01:37 PM Last Post: slowboy2 |
Collecting info for w58 conversion | ditn | 1 | 4,866 |
06-01-2012 08:59 PM Last Post: ditn |
Exedy 'S New Metal' Racing Clutch Kit Toyota 4AGE AE86, | dsrturbo | 2 | 5,905 |
07-28-2011 10:51 AM Last Post: Bean |
