what clutch for a W58 trans to a 4AGE Blacktop?
11-11-2011, 08:05 PM
If you don't want custom one, you can buy 1987 CE70 1,8 Diesel RWD clutch. I compared and checked it today, it fits perfect on W5X gearbox and exactly the same diameter as the one from blacktop. I will use it on my 4ag to W55 gearbox conversion.
11-16-2011, 03:02 PM
What diff and axle do you plan to use ?
Can standard axle with some aftermarket diff (TRD, KAAZ...) handle ~200 hp which good 4AGE can produce ?
11-16-2011, 05:34 PM
I am using this setup
In the past I had a 20v silvertop turbocharged, gts welded rear aprox 230 to the wheels with no problem on diff or transmission. now I switched to NA silvertop and trd lsd. the axles are ok and the transmission has no shift problems I drive the car hard but no drifting on stunt crazy driving.
After a couple of years I understood that balance is everything and fuel economy was priority, I pulled the turbo and bought an LSD Smile
Change your diff oil regularly
[Image: AEU86 AE86 - what clutch for a W58 trans... Blacktop?]
11-16-2011, 05:54 PM
Great, i knew W5x can handle that hp, but wasn't sure about diff.
I found W58 and now considering to swap T50 to W58.
My T50 is managing ~140hp pretty well, not sure if it will handle next power bump (hoping for 170+) but thinking it could.
So, the question is, is swaping to W58 worth if you consider only gear ratios.
As i see it 1st is a bit longer, 5th is much better for crusin but shift points in between are pretty much the same.
Is it worth trouble to switch to w58 just because of that ?
Thanks
p.s. What type of hard driving is your AE86 coping with ? Track or street ? Rally ? Smile
11-16-2011, 07:43 PM
Uzelac Wrote:Great, i knew W5x can handle that hp, but wasn't sure about diff.
Thanks
daily driving up to 7500 rpm and track driving ( not to often )
your clutch will be the weakest point
11-16-2011, 09:32 PM
Can a 4AGZE or 20v flywheel e fitted on blue 16v?
11-17-2011, 08:36 PM
i have a complete flywheel and clutch from a supra non turbo. this fit the blacktop engine and the w58 gearbox. Thumbs up!
thanks for all your help. Thumbs up! Thumbs up!
  stock injector deadtime for 4age 20v silvertop/blacktop injector ditn 1 5,855 02-20-2016 11:48 AM
  trans oil, lsd oil change Apolan 9 17,027 10-01-2014 03:57 PM
  7AGE to W58, cluth type? slowboy2 3 5,487 05-25-2013 01:37 PM
Last Post: slowboy2
  Collecting info for w58 conversion ditn 1 4,824 06-01-2012 08:59 PM
Last Post: ditn
  Exedy 'S New Metal' Racing Clutch Kit Toyota 4AGE AE86, dsrturbo 2 5,853 07-28-2011 10:51 AM
