what clutch would you recommend
10-13-2009, 01:56 PM
Hi all I've got a 1984 Corolla Levin pushing out about 160bhp, it currently has an Ogura race clutch which is pretty much impossible to use on the road. could anyone recommend me a clutch which i can use on the road but can handle the bhp or weather a standard AE86 clutch would be fine.
cheers |
10-13-2009, 03:01 PM
I got the Ogura 250light in mine.
Altough there are no springs on the clutch it works perfectly fine. Slipping point might be a bit short but you get used to it. This should handle up to 250hp. Cusco has also a very good clutch, they work really good. Speed Industries Hurdnerwaeldlistr. 73 8808 Pfaeffikon Switzerland e-mail: [email protected] phone: +4155 420 15 69 page: http://www.speed-industries.ch MSN: [email protected] We have all the parts your Hachi needs |
10-13-2009, 03:49 PM
cool cheers for the info, i'll look into and see how cheap i can get one
10-13-2009, 04:40 PM
Exedy clutches are good also. You might wanna consider them too. Specially stage 1 is very good option for you.
10-14-2009, 12:45 PM
I've heard alot of people say that standard clutches are pretty good
10-14-2009, 01:16 PM
Just get a heavy duty pressure plate (uprated clamping force), and use a conventional driven plate.
You will only run into problems if you severely abuse it with drifting techniques. Road or any other form of motorsport and you will be fine, plus it will be a lot nicer to drive. And get your flywheel resurfaced. |
10-14-2009, 08:15 PM
Hmmmmm, I know of a Giken clutch and flywheel combo for sale.......
depends on your budget http://hachiroku.net/forums/showthread.php?t=18950 Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
10-14-2009, 10:33 PM
750 is a little steep
lookin into stock clutch kit around 70 |
10-15-2009, 07:35 AM
How about those 6puck kits on ebay XTD i think at around $130 ???
AE86 FANATIC!!! |
10-15-2009, 09:48 AM
Like all Chinese stuff, some last forever, some disintegrate within a week of moderate use.
If you are still beneath, 175hp, don't do full on clutch kicking drift competition every weekend, then a bog standard LUK clutch will last you just fine and be a whole lot nicer to use every day. No fun having the clutch chatter every time you try to reverse somewhere. A wheel to steer the front of the car A pedal to steer the rear |
How would/have you rebuild your 4age? | joaotcgt | 6 | 8,926 |
07-21-2015 10:40 AM Last Post: mad.matt |
What camshafts would be nice? | PatrickAE86 | 44 | 40,121 |
08-25-2010 01:06 PM Last Post: Uzelac |
4age bogs. Would like some help! | root | 4 | 5,806 |
12-30-2009 11:10 AM Last Post: Nomuken |
Clutch Master Cylinder and Clutch Slave Cylinder fitment? | christsang7 | 2 | 5,079 |
07-01-2009 07:48 AM Last Post: jondee86 |
Clutch release bearing - do you have this part? | Apolan | 5 | 6,751 |
06-26-2009 02:11 AM Last Post: Apolan |
