what shocks/struts to buy?
05-03-2006, 10:43 PM
Hi all,
I have a update on the camaro Koni,and that is not going to happen,as they are not in Europe,and only go to the US market,so they will be really expinsive here. Then i tryed to get some prices on bilstein,as they are always a good product,but they also do not get the camaro shock to europa. And i would also first like to get the measurements of the shock before buying it. So rigt now i dont know what i will do, I can see that some in AU are using a Hilux front shock,or a pug 505 rear shock,this will be alot easyer to get here in Europe. http://www.garagedori.com/tech/suspensio..._guide.php Regards, Skassa Any fool can go fast in a straight line. VEMS Blacktop 4AGTE20V 272hp/350nm """www.turbotoys.dk""" |
05-04-2006, 09:01 AM
Hmm...Koni's main manufacturing site is located in the netherlands, 15 minutes drive from my parents place. If they make them there then surely they will sell them around here too..
05-04-2006, 12:23 PM
Contacted Intrax a few weeks ago for a question about coilovers for my dad's Camry. They where about 1300 euro. I couldn't resist to ask if they make coilovers for an AE86. If I'm not wrong the price is the same.
They are very nice and Intrax install them according to the wishes of the customer. http://www.intraxracing.nl 5/2018 BMW F22 Coupe 1/1985 Toyota AE86 Levin Coupe |
05-04-2006, 12:44 PM
You can get pretty decent coilovers for a lot less than 1300 euro's...that's more than twice what I paid for my car, or even 7 volvo's
05-04-2006, 01:34 PM
thats ALOOOOT of money
08-31-2006, 06:08 PM
hey guys i did some research for using camaro koni dampers on a ae86. I wrote a letter to koni about de conversion and i received some intresting information to share. I'm sorry it's Dutch, but feel free to translate it!
Admin: Please let me upload 2 pdf documents (technical drawings) of the camaro en the ae86 damper!! ------------------------------------------------------------------------------ Beste heer/mevrouw, Heeft u misschien digitaal een technische tekening met de afmetingen van een Koni gele achterdemper voor een Toyota Corolla GTS (AE86) bouwjaar ‘83-‘87 en één voor een ‘92-‘01 Camaro. Het is namelijk zo dat veel van onze leden op het forum (http://www.aeu86.org) op zoek zijn naar een kortere demper voor een Toyota AE86. Nu wordt bij verlaging aan de voorkant gebruik gemaakt van een gele Koni Toyota AE92 demper, maar is er achter tot zover nog niet geëxperimenteerd met andere dempers van Koni. In Amerika wordt als kortere achter sportdemper een demper voor een Camaro van het merk KyB AGX gebruikt. Aangezien wij in Nederland wonen en nogal pro Koni zijn, zouden wij willen weten of de afmetingen voor het bevestigen overeenkomen met die van een AE86 demper en klopt het dat de demper inderdaad ongeveer 4 cm korter is dan die van een AE86 demper. Ik hoop dat u ons hier een antwoord op kan geven of in ieder geval de afmetingen van beide dempers. Dan weet ik in ieder geval wat ik ga kopen. Alvast bedankt, Jordie van Hese ----------------------------------------------------- Beste Jordie, bijgevoegd vindt je de gevraagde tekeningen. Persoonlijk zie ik het echter niet zo zitten om deze dempers uit te wisselen. Zoals je op tekening kunt terugvinden, is de demper inderdaad 61 mm korter. De bovenbevestiging is in plaats van M10x1 (op de Corolla) M12x1.25 op de Camaro. De bodembevestiging heeft nu een pen van 16 mm, de camaro heeft een ingeperste bevestiging, deze zal moeilijk te verwijderen zijn. Wanneer je deze eruit kunt krijgen, houdt je een rubber over met een binnendiameter van 10 mm, wat een beetje te klein zal zijn. Om je van een goed advies te kunnen dienen heb ik ons systeem gezocht naar een alternatief. De bovenbevestiging is redelijk algemeen voor een demper van deze afmetingen, maar de bodembevestiging is absoluut uniek. De bodem van de meeste dempers heeft een oog met een gevulkaniseerd rubber, waardoorheen de pen wordt bevestigd. Waarschijnlijk is bij de Corolla een pen aan het voertuig bevestigd, waar dit rubber omheen wordt gedrukt? Het is een hele toer om het rubber te vervangen, en dan is de vraag of het goede rubber te verkrijgen is. Mochten jullie interesse hebben om de standaard Corolla achterdemper te laten inkorten, dan kun je misschien eens navraag doen bij Suspension Centre: Suspension-Centre Dhr. Mark Holthuis Joh.Bogaardstraat 21 2151 CT NIEUW VENNEP Tel. 0252-675209 / 06-53519308 Fax. 0252-672846 Hij kan tegen een schappelijk prijsje voor jullie wat aanpassingen verrichten, want het lijkt me verstandig om ook de krachten aan te passen aan de kortere slag. De standaarddemper (ons bestelnummer 80-2437SPORT) als uitgangspunt nemen heeft grote voordelen, niet alleen qua maatvoering, maar ook de krachten zijn al op de auto afgepast. Bedankt voor je interesse in onze producten. Met vriendelijke groet, Pieter Blom Product Management - Cars & Racing Tel. +31 (0)186 - 635650 Fax. +31 (0)186 - 635612 Koni BV P.O. Box 1014 3260 AA Oud Beijerland Holland [/i] 5/2018 BMW F22 Coupe 1/1985 Toyota AE86 Levin Coupe |
08-31-2006, 08:20 PM
Damn you,
I send an email to koni and it just bounces, you send an email and you get a reply hehehehe Sounds like alot of money to waiste if we can just order AGX or Tokico for less money then the Koni's and get directly what we want.. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
08-31-2006, 08:34 PM
hehhe had to wait more that 2 weeks!!
Exactly! I stick to the idea to buy Tokico HTS shortstoke 5/2018 BMW F22 Coupe 1/1985 Toyota AE86 Levin Coupe |
08-31-2006, 09:09 PM
I removed the email addresses: otherwise they might get spammed
1982 - TA60 Carina 4dr sedan - fun cruiser 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
09-03-2006, 12:39 AM
But if you already have koni yellow rears, you could get them refurbed wile you have them shortened. Instead of throwing you cash at the AGXes. If I read the email correctly they shorten the damper and adjust valving to suit. Somehow I prefer Koni above most anything else.. just going from the few experiences have had with shocks so far.
rear bilstein B6 shocks 2 types what to choose? | Ryo | 5 | 3,012 |
KONI Sports shocks for the AE86... | jondee86 | 11 | 20,184 |
Camber adjustment vs original struts | Lt86 | 9 | 9,113 |
05-07-2015 09:45 PM Last Post: zenki |
Question about KONI shocks for an AE92 | Apsogos | 1 | 3,998 |
09-13-2013 07:40 AM Last Post: Apsogos |
Q, BMW E30/E36 front struts for a fit? | Allexz | 7 | 8,405 |
03-18-2013 11:18 AM Last Post: Lajoosh |
