what shocks/struts to buy?
05-03-2006, 10:43 PM
Hi all,
I have a update on the camaro Koni,and that is not going to happen,as they are not in Europe,and only go to the US market,so they will be really expinsive here.
Then i tryed to get some prices on bilstein,as they are always a good product,but they also do not get the camaro shock to europa.
And i would also first like to get the measurements of the shock before buying it.
So rigt now i dont know what i will do,
I can see that some in AU are using a Hilux front shock,or a pug 505 rear shock,this will be alot easyer to get here in Europe.
http://www.garagedori.com/tech/suspensio..._guide.php
Regards,
Skassa
"""www.turbotoys.dk"""
05-04-2006, 09:01 AM
Hmm...Koni's main manufacturing site is located in the netherlands, 15 minutes drive from my parents place. If they make them there then surely they will sell them around here too..
05-04-2006, 12:23 PM
Contacted Intrax a few weeks ago for a question about coilovers for my dad's Camry. They where about 1300 euro. I couldn't resist to ask if they make coilovers for an AE86. If I'm not wrong the price is the same.
They are very nice and Intrax install them according to the wishes of the customer.
http://www.intraxracing.nl
[Image: AEU86 AE86 - what shocks/struts to buy?]
05-04-2006, 12:44 PM
You can get pretty decent coilovers for a lot less than 1300 euro's...that's more than twice what I paid for my car, or even 7 volvo's Big Grin
05-04-2006, 01:34 PM
thats ALOOOOT of money Huh
08-31-2006, 06:08 PM
hey guys i did some research for using camaro koni dampers on a ae86. I wrote a letter to koni about de conversion and i received some intresting information to share. I'm sorry it's Dutch, but feel free to translate it! Big Grin
Admin: Please let me upload 2 pdf documents (technical drawings) of the camaro en the ae86 damper!!
Beste heer/mevrouw,
Heeft u misschien digitaal een technische tekening met de afmetingen van een Koni gele achterdemper voor een Toyota Corolla GTS (AE86) bouwjaar ‘83-‘87 en één voor een ‘92-‘01 Camaro.
Het is namelijk zo dat veel van onze leden op het forum (http://www.aeu86.org) op zoek zijn naar een kortere demper voor een Toyota AE86. Nu wordt bij verlaging aan de voorkant gebruik gemaakt van een gele Koni Toyota AE92 demper, maar is er achter tot zover nog niet geëxperimenteerd met andere dempers van Koni. In Amerika wordt als kortere achter sportdemper een demper voor een Camaro van het merk KyB AGX gebruikt. Aangezien wij in Nederland wonen en nogal pro Koni zijn, zouden wij willen weten of de afmetingen voor het bevestigen overeenkomen met die van een AE86 demper en klopt het dat de demper inderdaad ongeveer 4 cm korter is dan die van een AE86 demper.
Ik hoop dat u ons hier een antwoord op kan geven of in ieder geval de afmetingen van beide dempers. Dan weet ik in ieder geval wat ik ga kopen.
Alvast bedankt,
Jordie van Hese
Beste Jordie,
bijgevoegd vindt je de gevraagde tekeningen. Persoonlijk zie ik het echter niet zo zitten om deze dempers uit te wisselen. Zoals je op tekening kunt terugvinden, is de demper inderdaad 61 mm korter. De bovenbevestiging is in plaats van M10x1 (op de Corolla) M12x1.25 op de Camaro. De bodembevestiging heeft nu een pen van 16 mm, de camaro heeft een ingeperste bevestiging, deze zal moeilijk te verwijderen zijn. Wanneer je deze eruit kunt krijgen, houdt je een rubber over met een binnendiameter van 10 mm, wat een beetje te klein zal zijn.
Om je van een goed advies te kunnen dienen heb ik ons systeem gezocht naar een alternatief. De bovenbevestiging is redelijk algemeen voor een demper van deze afmetingen, maar de bodembevestiging is absoluut uniek. De bodem van de meeste dempers heeft een oog met een gevulkaniseerd rubber, waardoorheen de pen wordt bevestigd. Waarschijnlijk is bij de Corolla een pen aan het voertuig bevestigd, waar dit rubber omheen wordt gedrukt? Het is een hele toer om het rubber te vervangen, en dan is de vraag of het goede rubber te verkrijgen is. Mochten jullie interesse hebben om de standaard Corolla achterdemper te laten inkorten, dan kun je misschien eens navraag doen bij Suspension Centre:
Suspension-Centre
Dhr. Mark Holthuis
Joh.Bogaardstraat 21
2151 CT NIEUW VENNEP
Tel. 0252-675209 / 06-53519308
Fax. 0252-672846
Hij kan tegen een schappelijk prijsje voor jullie wat aanpassingen verrichten, want het lijkt me verstandig om ook de krachten aan te passen aan de kortere slag. De standaarddemper (ons bestelnummer 80-2437SPORT) als uitgangspunt nemen heeft grote voordelen, niet alleen qua maatvoering, maar ook de krachten zijn al op de auto afgepast.
Bedankt voor je interesse in onze producten.
Met vriendelijke groet,
Pieter Blom
Product Management - Cars & Racing
Tel. +31 (0)186 - 635650
Fax. +31 (0)186 - 635612
Koni BV
P.O. Box 1014
3260 AA Oud Beijerland
Holland
[/i]
08-31-2006, 08:20 PM
Damn you,
I send an email to koni and it just bounces, you send an email and you get a reply hehehehe Big Grin
Sounds like alot of money to waiste if we can just order AGX or Tokico for less money then the Koni's and get directly what we want..
08-31-2006, 08:34 PM
hehhe had to wait more that 2 weeks!! Tongue
Exactly! I stick to the idea to buy Tokico HTS shortstoke
08-31-2006, 09:09 PM
I removed the email addresses: otherwise they might get spammed Wink
09-03-2006, 12:39 AM
But if you already have koni yellow rears, you could get them refurbed wile you have them shortened. Instead of throwing you cash at the AGXes. If I read the email correctly they shorten the damper and adjust valving to suit. Somehow I prefer Koni above most anything else.. just going from the few experiences have had with shocks so far.
  rear bilstein B6 shocks 2 types what to choose? Ryo 5 3,145 07-25-2021 04:41 AM
  KONI Sports shocks for the AE86... jondee86 11 20,399 09-08-2017 03:38 AM
Last Post: jondee86
  Camber adjustment vs original struts Lt86 9 9,275 05-07-2015 09:45 PM
Last Post: zenki
  Question about KONI shocks for an AE92 Apsogos 1 4,032 09-13-2013 07:40 AM
Last Post: Apsogos
  Q, BMW E30/E36 front struts for a fit? Allexz 7 8,496 03-18-2013 11:18 AM
Last Post: Lajoosh
User(s) browsing this thread: 12 Guest(s)
