Ricks project AE85 (Back together with dyno results)
12-12-2006, 12:10 PM
Hi I am a new member and this is my project car.
I couldnt afford to pay the overinflated prices for a AE86 so I ended up with a AE85 as my project car..
When my AE-85 is finally finished it will be used on the road as well as used for tarmac track racing, hillclimbs etc.. nothing to serious but just for a bit of fun.
Currently I am test fitting every thing first, then the car will be stripped down again and painted and reassembled. The Motor, gearbox, diff, front and rear suspension, rollcage have been installed, there is tones more to do but the next step is to sort out the rear guards requiring some sort of flare or body kit.
A few Details so far (I will try and keep updated):
Powertrain
AE101 4AGZE supercharged motor
2 1/4 exhaust system
Subaru water to air intercooler
Hilux diff, LSD
Supra gearbox
Custom bellhousing
Custom single piece drive shaft.
TRD Engine mounts
Suspension:
MA61 supra front struts
MA61 supra front disk brakes
AE92 levin/trueno rear disk brakes
TRD race springs
Tokico Adjustable shocks all round
Whiteline front adjustable swaybar
Whiteline rear adjustable swaybar
Whiteline adjustable panhard rod
Whiteline adjustable trailing arms
Adjustable caster arms
Adjustable camber plates
Custom NRCA's
Traction brackets
New bushes all round
Wheels and tires:
15x6.5 Fortran? rims for now.
Body:
8 piont roll cage
Rear shock absorber tower brace
TRD wing/fiberglass hatch
Fiberglass rear guards
This how she looked when I first I bought it back in 2004, stock standard
[Image: AEU86 AE86 - Ricks project AE85 (Back to...o results)]
Within the first few weeks of owning it I started to strip it down and began work on the removel of the rust. Which I took my time with as I have seen so many rust repair jobs done poorly with rust repairing in a matter of months.
Just before it went away to get the rollcage fitted
This is after I got it back from getting the rollcage installed, I was very impressed with the quality of workmanship. Cool
I bar that I added in myself (between the rear shock towers)
This is the motor I will be using 4agze out of a AE-101 I will be keeping the supercharger on it and will be running the factory ECU, but I am going to rearange the intake setup to make it flow abit better (hopefully) using a big port rwd intake manifold.
4AGZE bolted to W55 with custom belhousing
Cutting mounts off the AE85 diff
Positioning AE85 mounts onto hilux diff.
Hilux diff with AE-85 mounts welded on.
Maching down axle and getting ready to Re-stud axles
Test fitting the diff once it had been painted
Custom made gearbox crossmember using factory W55 rubber mount
Shortened MA61 struts with TRD race springs, tokico shocks, adjustable camber plates.
Supra brakes with custom NRCA (Negative Roll Centre Adjusted) fitted.
After market fan mounted onto (cough) honda integra radiator, twin core.
I planed on mounting the race seats onto the factory rails but because I am a tall bugger my head was hitting the roof and that was without a helmet on, so new seat mounting points were made, they sit much lower and further back.
Sorting out the fuel surge tank setup in a mock up cardboard box.
Box all welded up, ready for the goodies to go in.
Goodies in place and sitting in car.
Facet lift pump, bosch 910 main pump.
Making new stainless lines to go into fuel tank
Test fitting motor
Making up brackets for the intercooler, radiator brackets etc..
Subaru water to air intercooler setup:
Engine cross member painted and steering rack rebuilt, new swaybar along with new bushes fitted all round.
Test fitting/mounting fibreglass rear guards
Corolla Levin SR 1984 AE-85 (Project car)
Corolla Runx Z 2002 (Runabout)
12-12-2006, 12:43 PM
Hi There
Great looking project.
I have heard a lot of hilux Diff being used - what are the major advantages of it?
Regards Johnny
why go forward when you can go sideways
12-12-2006, 01:50 PM
Very nice project. Thumbs up!
In other words: your AE85 is becoming an AE86 after the rebuild. Smile
Are you going to put N2 flares up front as well? Dumb question
12-12-2006, 07:15 PM
The hilux diff is pracitcally indestructible johnny.. that'sthe main advantage. Should you manage to destroy it, the 7 inch ring and pinions are available a lot cheaper than the regular 6.7 stuff since all the off-road (r&p killing) people have ensured a bigger aftermarket. That way you can get american made r&p's, which are usually a lotcheaper than the japanese counterparts.
12-12-2006, 07:39 PM
man this car is so cool
was thinking, where do you find these ae85's, I've looked for them but never have found any, apart from in America,
Good luck with the project
12-13-2006, 06:00 AM
johnny_and Wrote:Hi There
Regards Johnny
As said above they are pretty much indestructible, plus an AE86 lsd rear ends are around $1000 NZD to buy here, wont handle as much power etc etc.. The supra gearbox and hilux diff combination, is a good one, a fair few AE86 owers here use this type of setup in there drift cars where they cop heaps of abuse like clutch kicks etc.
banpei Wrote:Very nice project. Thumbs up!
Sort of, if anything it should be better than a factory AE86 (dont hit me :wink: )
At this stage it will only have rear flares..
Elid Wrote:man this car is so cool
My one was imported from japan.
12-13-2006, 04:23 PM
From Japan
thats cool, how much was it in yen, must be like £500 pounds, alot cheaper than an 86 for sure, plus is it worth getting an ae85 and making it into an ae86 (money wise)
12-13-2006, 10:15 PM
mmm, as far as I can remember also Australia should be a 85-paradise. Wink
12-13-2006, 10:51 PM
Get me a AE85 i got plenty o parts to make it an ae86 ;-) about 3 times ;P
But seriously. THis is one nice car. Where the hell you got that hilux diff???
You be getting a
AME86 with those supra parts installed Tongue
12-14-2006, 06:58 AM
Elid Wrote:From Japan
I didnt import it myself it was imported/registered in new zealand in June 1989. I bought it in 2004. I went for the ae85 because its cheaper than a ae86 and even if I did buy a ae86 I wouldnt be using any of the drivetrain, motor, gearbox etc so it would have been a waste. If i had a oringinal ae86 I would want to restore it to factory condition not turn it into a race car.
banpei Wrote:mmm, as far as I can remember also Australia should be a 85-paradise. Wink
No, unless they where privately imported as far as Iam aware.. They had AE86 baged cars sold new there from 1983-1984, however they are not a ture ae86, they were sold with a 4AC motor,single cam, carbs, solid front discs, drum rear end. Only sold with levin style fronts and sprinter tail lights.
robokill Wrote:Get me a AE85 i got plenty o parts to make it an ae86 ;-) about 3 times ;P
You be getting a
From a Hilux of course Tongue
  Ae85 Minidaxman 4 3,515 04-20-2021 09:57 PM
  time to get her back on the road.. worholm 4 6,501 01-21-2017 09:33 AM
Last Post: worholm
  AE85 Power! From 175HP 20v to 202HP F20 4000GT 23 30,439 10-16-2014 02:53 PM
  Sam's AE85 Conversion Sambo 2 14,526 05-20-2014 05:03 AM
Last Post: Sambo
  Stalkers daily AE85 - 7AGE stalker 32 44,358 12-28-2011 02:28 PM
Last Post: stalker
