1/8 BSPT adapter for oil pressure sensor
06-14-2013, 07:56 PM
So, I bought a oil pressure switch from an AE92 to fit Oil-P warning light. It's also 1/8BSPT as the original sensor in the AE86.
Since I want to keep the original sensor also,I wanted to buy a T piece with 1x male 2x female 1/8 bspt.
But it seems impossible to find it. Confused
Anyone knows where to buy it?
Or,
- Can I fit 1/8 BSP onto BSPT? Is the thread in the Engine BSP or BSPT? I could find Y piece with 3x 1/8 BSP.
- Many T pieces are 1/8BSPT male and 1/8BSP + 1/8 NPT female.
But than I can not find a adapter from 1/8NPT to 1/8 BSPT.
Any help/advice is welcome.
Thanks already.
06-14-2013, 10:53 PM
Do not put those straight to the block, because it could crack easily.
Go to the hydraulic shop and ask them to make you a 30-40cm long teflon hose with male ends. Put that in the block.
Then 3xfemale T-piece and put it next to the hose and put sensors to it.
[Image: AEU86 AE86 - 1/8 BSPT adapter for oil pressure sensor]
"Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!"
""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff"
-Henri Toivonen 2.5.1986-
http://www.youtube.com/watch?v=OwgB4Xs4LVQ
06-15-2013, 10:01 AM
That's looks good.
And indeed two sensors straight on the block might be to heavy and crack.
I will copy your layout, with you permission :wink:
Than one question I have:
The female side is PSB or also BSPT? (T piece)
If I use BSP it will seal on the BSPT male by itself?
Thanks a lot.
06-15-2013, 12:34 PM
Go ahead, I have copy that also :wink:
All parts a bought in hydraulic shop.
I think that T-piece is a BSPT
  Lambda sensor wiring sam3007 10 4,633 05-23-2022 10:00 PM
Last Post: The Doctor
  Build your own adjustable fuel pressure regulator ;) oldeskewltoy 8 21,237 08-19-2018 12:08 PM
Last Post: AlexKTM
  Oil Pressure Query Alex170984 2 5,224 12-11-2014 01:25 AM
Last Post: Alex170984
  trans oil, lsd oil change Apolan 9 17,233 10-01-2014 03:57 PM
  AE86 Engine Coolant Temp Sensor izanagi 8 20,507 09-06-2014 05:47 PM
Last Post: izanagi
