1/8 BSPT adapter for oil pressure sensor
06-14-2013, 07:56 PM
So, I bought a oil pressure switch from an AE92 to fit Oil-P warning light. It's also 1/8BSPT as the original sensor in the AE86.
Since I want to keep the original sensor also,I wanted to buy a T piece with 1x male 2x female 1/8 bspt. But it seems impossible to find it. ![]() Anyone knows where to buy it? Or, - Can I fit 1/8 BSP onto BSPT? Is the thread in the Engine BSP or BSPT? I could find Y piece with 3x 1/8 BSP. - Many T pieces are 1/8BSPT male and 1/8BSP + 1/8 NPT female. But than I can not find a adapter from 1/8NPT to 1/8 BSPT. Any help/advice is welcome. Thanks already. |
06-14-2013, 10:53 PM
Do not put those straight to the block, because it could crack easily.
Go to the hydraulic shop and ask them to make you a 30-40cm long teflon hose with male ends. Put that in the block. Then 3xfemale T-piece and put it next to the hose and put sensors to it. ![]() "Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!" ""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff" -Henri Toivonen 2.5.1986- http://www.youtube.com/watch?v=OwgB4Xs4LVQ |
06-15-2013, 10:01 AM
That's looks good.
And indeed two sensors straight on the block might be to heavy and crack. I will copy your layout, with you permission :wink: Than one question I have: The female side is PSB or also BSPT? (T piece) If I use BSP it will seal on the BSPT male by itself? Thanks a lot. |
06-15-2013, 12:34 PM
Go ahead, I have copy that also :wink:
All parts a bought in hydraulic shop. I think that T-piece is a BSPT "Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!" ""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff" -Henri Toivonen 2.5.1986- http://www.youtube.com/watch?v=OwgB4Xs4LVQ |
Lambda sensor wiring | sam3007 | 10 | 4,801 |
Build your own adjustable fuel pressure regulator ;) | oldeskewltoy | 8 | 21,585 |
Oil Pressure Query | Alex170984 | 2 | 5,323 |
12-11-2014 01:25 AM Last Post: Alex170984 |
trans oil, lsd oil change | Apolan | 9 | 17,476 |
AE86 Engine Coolant Temp Sensor | izanagi | 8 | 20,721 |
