20V BT in AE86 idling problems.
01-19-2007, 09:44 AM
Guys any of you guys using black top (open trumpet) with just fuel regulator for fueling using back the std BT ecu and wiring. I'm having problem with the fueling the engine seems lethargic to move during low rpm.And the idling seems rather erratic with the air-con on. I'm using back the 86 aircon compressor. My mechanic suggest me to use back the BT air-con compressor because he said that the BT air-con is lighter so does not lower down the rpm when the compressor is activated. Any help?
  Big wheel problems gh0st 16 8,168 11-15-2021 10:51 PM
Last Post: gh0st
  Starting problems 4-AGE kouki Hanzo 3 2,633 08-31-2021 06:20 PM
Last Post: totta Crolla
  Problems Mintex M1155 pads Dino86 9 8,899 07-04-2017 11:22 AM
  16v Bigport fuel problems Rascal21 1 4,743 07-04-2015 01:00 AM
Last Post: jondee86
  Starter problems Widar 49 121,178 02-09-2015 10:11 AM
