20V Blacktop oil pressure?
11-26-2010, 10:38 PM
what is the oil pressure for a blacktop 20v?
cold en hot oil temp.
i have a TRD oilfilter en castrol 10W40 oil. my presure is cold 6.2 bar.
and hot around 3.2 bar. 1800 RPM. is this normal?
11-27-2010, 11:59 AM
My oil pressure with 5W50 oil is 2-2.5 bar at idle, so i guess its normal Big Grin
11-28-2010, 06:10 AM
slowboy2 Wrote:...presure is cold 6.2 bar.
That is higher then it should be if the gauge is accurate. Has anyone stuck a shim in the oil pump relief valve? I hope it isn't going any higher then that when it's cold & revved up! Huh
11-28-2010, 12:08 PM
when it is cold and i rev it up it go to 7 bar.
when it is hot it wil go to max 6 bar.
idle cold is 6.2 and idle hot is 3.2
first it was cold 5.5 bar en hot 3 bar idle. and max 6 bar reving.
i have cleaned the sensor for the vvti. is this the problem?
where can i find the oil pump relief valve?
11-29-2010, 09:42 AM
slowboy2 Wrote:when it is cold and i rev it up it go to 7 bar.
You've got an optimistic gauge or a valve someone has F'd with. Your losing some HP from the extra/useless pressure it's putting out and and have a chance of popping the filter or breaking the pump.
I don't understand 'first', first what, before the vvti sensor thing?
Valve is on the pump body.
11-29-2010, 08:58 PM
i have cleaned the sensor in front of the exhaust manifold.
[Image: AEU86 AE86 - 20V Blacktop oil pressure?]
and after that i get more oil presure.
my engine is also very dirty.
can this be the problem?
this foto is from a year ago.
11-29-2010, 09:39 PM
Looks like a stereotypical 'low mileage' + low maintenance 20v.
Caked oil crust everywhere. Isnt there a temp sensor in the head that's related to this issue in blacktops? My friend had one and told me about it, but he sold the car a long time ago already.
12-03-2010, 08:52 PM
thanks. i wil look at the oil pump asap.
my oil pressure is now about 7 bar cold. but it is cold here. Tongue
at ivan141: bedoel je toevallig de koelvloeistof sensor achter in de kop. bij het thermostaat huis? er zitten daar 3 sensoren 1 voor de airco. 1 voor de temp sensor voor dashboard en 1 voor de computer. welke kan dan het probleem geven?
sorry that it is not in english.
12-03-2010, 09:30 PM
Dunno to be honest.. just something I overheard. Many engines have the sensor in the back of the cyl.head.
The caked oil is a direct result of the combination: high engine temp, not enough oil changes. 20v's require more frequent oil changes due to the high temps.
  Refreshed 20v blacktop first start.. Mylesmck 6 891 10-07-2024 07:55 AM
  20v Blacktop conversion.... Mylesmck 0 519 04-29-2024 05:48 PM
Last Post: Mylesmck
  Improve 20V Blacktop cooling pack 0 1,034 06-07-2023 01:18 PM
Last Post: pack
  20v BT - which oil pump? Mylesmck 4 2,888 06-21-2022 04:51 PM
Last Post: pack
  Build your own adjustable fuel pressure regulator ;) oldeskewltoy 8 21,292 08-19-2018 12:08 PM
Last Post: AlexKTM
