20v/16v lightweight pulley kits
11-07-2011, 12:43 PM
I was wondering if it is possible to use a full 16v pulley kit (crank, alternator and water pump) in a 20V engine (with 20v alternator and waterpump)
I'm under the impression that they cannot be mix matched (16v and 20v pulleys in the same engine) due to a misalignment between the crank and the alternator pulleys, but I am not sure if it is possible to use a complete kit from the 16v on 20v peripherals.
Can anyone shed some light on this issue?
Regards
86'LEVIN Track Project
11-07-2011, 12:57 PM
My friend use a complete 16v pulley kit on his blacktop (just add a small spacer under the alternator pulley for the misalignment)
Sadly I don't have any picture
11-07-2011, 01:14 PM
Thanks for the quick reply Project D. Smile
Is your friend using only 20v components (alternator and waterpump)?
If he is, then I guess I'll go with a 16v pulley kit.
The spacer seems a easy enough mod that should not prevent the kit from performing correctly. :wink:
Also, the crank pulley only uses one row, right? The second outer row shouldn't be necessary if your're not running AC/PS. Dumb question
11-07-2011, 04:53 PM
Far as I know my friend use 20V components yes.
And single row crank pulley is perfect if you don't have AC/PS Smile
My friend use the red set, I use the gold one (on my 16v)
[Image: AEU86 AE86 - 20v/16v lightweight pulley kits]
(all parts made by aussifan, some with my very own specs Tongue )
11-08-2011, 01:53 PM
Thanks for the input Project D. Thumbs up!
Do you remember what was the thickness of the spacer to make up for the misalignment?
11-08-2011, 04:28 PM
I don't remember but it will not hard to sort it out.
By putting the 2 pulleys side by side you will be able to mesure the exact tickness you will need.
11-08-2011, 04:54 PM
Right.
Will do as soon as I get them from aussiefan. Thanks! Smile
  How to install 20V ITB on 16V head Mr.komp 7 11,744 12-28-2015 05:35 PM
Last Post: pack
  4AGE overhaul kits/ Brian Crower stroker kit Lt86 1 4,103 06-13-2015 06:53 PM
Last Post: corolla4agze
  16V ECU pinout on 20v swap pack 2 5,475 06-12-2015 01:22 AM
Last Post: pack
  20v block with 16v head and internals possible? ditn 3 7,009 08-12-2014 09:19 PM
Last Post: ditn
  20v with 16v Water Relocation Kit D.O 9 15,885 06-12-2014 02:48 AM
Last Post: jondee86
