20v Blacktop conversion....
04-29-2024, 05:48 PM (This post was last modified: 04-29-2024 05:49 PM by Mylesmck.)
Hi Folks,
My 4age rebuild is nearing completion, and again I'm after some help Confused
What do people usually do about the engine - gearbox brackets? there's 2 mounting holes on each side of the block for them, one of which is now used for the engine mounting brackets in rwd configuration. Are these brackets required? If so, would it be ok to cut them down to one bolt to the block and two bolts to the bellhousing on each side?
Also, Valve lash caps, is it ok to sand these down using some fine (1000 GRIT) paper? They're quite tight following on from a little valve lapping, and the smallest size from Toyota is 1.70mm
Thanks
  Refreshed 20v blacktop first start.. Mylesmck 6 1,747 10-07-2024 07:55 AM
  Kouki to Zenki Levin grill conversion? Mylesmck 6 3,594 02-08-2024 10:30 AM
Last Post: r.ave
  Improve 20V Blacktop cooling pack 0 1,384 06-07-2023 01:18 PM
Last Post: pack
  AFM to Map Conversion ps13michi 3 4,327 01-06-2022 10:34 AM
Last Post: ps13michi
  Sub panel and rotary-button replacement for Levin -> Trueno conversion gh0st 9 6,980 11-05-2021 08:17 PM
Last Post: gh0st
