2nd gear
10-30-2004, 12:36 AM
2nd gear
What's the speed @7k RPM in 2nd gear with stock gears?
10-30-2004, 08:16 AM
2nd gear
Oohh.. not sure, I'd have to test that out on the road. I think around 90 or something...
10-30-2004, 12:40 PM
2nd gear
1 = aropund 50
2= around 95
3=around 140
4=200 = 7600
5= rest (depends ons tate of the engine etc)
10-30-2004, 03:13 PM
2nd gear
Are you sure? Looking at the gearboxratio's it seemed like 2nd-4th gear are close-ratio. The final gear is 4.3 right? That's pretty low...I'm surprised 2->3 is like a 45km/h difference. Seems a bit too much for a 124hp engine.
10-30-2004, 09:20 PM
2nd gear
I think it's more like 85 km/h in 2nd gear. The gearbox is insanely close-ratio on an ae86. It really tires me on freeway driving since it makes quite some noise at a constant 4000 rpm (despite the oem exhaust).
It has it's advantages for sporty driving, but is a bit tiring at cruising speeds. My perception of this might also be influenced by engine performance a bit since my idle is to high and the low-end torque is not what is used to be on my old engine.
10-30-2004, 09:47 PM
2nd gear
Aico, you got nearly 8000rpm to play with. There is roughly 500 rpm between gears. This box been designed to have a choice of multiple gears for each speed and have power availableSmile
12-04-2004, 01:08 AM
2nd gear
mux213 Wrote:Aico, you got nearly 8000rpm to play with. There is roughly 500 rpm between gears. This box been designed to have a choice of multiple gears for each speed and have power availableSmile
MUX...
about 700-1300 rpm steps
1st - 45 km/h
2:nd - 85 km/h
3:rd - 140 km/h
4:th - 185 km/h
5:th - 215 km/h @ 400 rpm overrev
Roughly translates inte 197 km/h according to TOYOTA specs
12-04-2004, 01:53 AM
2nd gear
My Hachi goes 198 km/h at 7200 rpm, tested with a GPS-tracker. Allthough the odometer shows nearly 220, it will not go more than 198 (with 3 gyus in the car) Smile
12-04-2004, 02:39 AM
2nd gear
12-04-2004, 02:52 AM
2nd gear
Hehe, i know my odometer is f@£ked up.. Yours is probably more realistic..
Found a picture i thought you should see Tongue
  5th gear issue r.ave 1 2,670 03-14-2021 08:52 PM
  ring gear bolts DJexor 3 5,542 12-26-2016 10:56 PM
Last Post: totta Crolla
  T50 gearbox - TRD 2nd and 3rd gear hachirokkos 3 6,771 11-27-2015 10:06 AM
Last Post: Project D
  Decently heavy vibration in fourth gear between 2000-2300rpm dinkers542 4 5,680 11-29-2014 12:27 AM
Last Post: dinkers542
  Checking ring gear diff izanagi 3 5,182 07-09-2014 07:38 AM
Last Post: jondee86
