2nd gear
10-30-2004, 12:36 AM
2nd gear
What's the speed @7k RPM in 2nd gear with stock gears?
10-30-2004, 08:16 AM
2nd gear
Oohh.. not sure, I'd have to test that out on the road. I think around 90 or something...
Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
10-30-2004, 12:40 PM
2nd gear
1 = aropund 50
2= around 95 3=around 140 4=200 = 7600 5= rest (depends ons tate of the engine etc) Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
10-30-2004, 03:13 PM
2nd gear
Are you sure? Looking at the gearboxratio's it seemed like 2nd-4th gear are close-ratio. The final gear is 4.3 right? That's pretty low...I'm surprised 2->3 is like a 45km/h difference. Seems a bit too much for a 124hp engine.
10-30-2004, 09:20 PM
2nd gear
I think it's more like 85 km/h in 2nd gear. The gearbox is insanely close-ratio on an ae86. It really tires me on freeway driving since it makes quite some noise at a constant 4000 rpm (despite the oem exhaust).
It has it's advantages for sporty driving, but is a bit tiring at cruising speeds. My perception of this might also be influenced by engine performance a bit since my idle is to high and the low-end torque is not what is used to be on my old engine. FABRICA MI DIEM, PVNC! |
10-30-2004, 09:47 PM
2nd gear
Aico, you got nearly 8000rpm to play with. There is roughly 500 rpm between gears. This box been designed to have a choice of multiple gears for each speed and have power available
![]() Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
12-04-2004, 01:08 AM
2nd gear
mux213 Wrote:Aico, you got nearly 8000rpm to play with. There is roughly 500 rpm between gears. This box been designed to have a choice of multiple gears for each speed and have power available MUX... about 700-1300 rpm steps 1st - 45 km/h 2:nd - 85 km/h 3:rd - 140 km/h 4:th - 185 km/h 5:th - 215 km/h @ 400 rpm overrev Roughly translates inte 197 km/h according to TOYOTA specs I´m sorry sir, your planet has been sceduled for destruction in favor of an intergalactic highway -Thank you Kristian Hesselmark, Sweden EVO-DRIFT-STREET-DRAG-SHOW |
12-04-2004, 01:53 AM
2nd gear
My Hachi goes 198 km/h at 7200 rpm, tested with a GPS-tracker. Allthough the odometer shows nearly 220, it will not go more than 198 (with 3 gyus in the car)
12-04-2004, 02:39 AM
2nd gear
12-04-2004, 02:52 AM
2nd gear
Hehe, i know my odometer is f@£ked up.. Yours is probably more realistic..
Found a picture i thought you should see ![]() Youtube Myspace and I´ll Google your Yahoo |
5th gear issue | r.ave | 1 | 2,670 |
03-14-2021 08:52 PM Last Post: Ivan141 |
ring gear bolts | DJexor | 3 | 5,542 |
12-26-2016 10:56 PM Last Post: totta Crolla |
T50 gearbox - TRD 2nd and 3rd gear | hachirokkos | 3 | 6,771 |
11-27-2015 10:06 AM Last Post: Project D |
Decently heavy vibration in fourth gear between 2000-2300rpm | dinkers542 | 4 | 5,680 |
11-29-2014 12:27 AM Last Post: dinkers542 |
Checking ring gear diff | izanagi | 3 | 5,182 |
07-09-2014 07:38 AM Last Post: jondee86 |
