4A's Engine's
09-10-2004, 11:48 AM
4A's Engine's
The 4A-GE has many conversions
4A = the name of the lower block
GE = the type and head name
4A-FE
FE = the economic version
4A-GZE
same as the 4age except the Z stand for supercharger (used in mr2 AW11, Toyota Corolla Levin - Trueno AE92 AE101)
4A-GTE
T Stands for turbo this engine was never originally build it has been a conversion of a gze or ge with a turbo on it
4age is an 16 V engine
later the 4age got a 20V younger brother in 2 verisons
AE101 silvertop 20V 160hp in the engine
AE111 Blacktop 20V 165-170hp in the engine
this version has variable valve timing to compete with Honda V-tec engines.
the 4age is in 2 difrent lower blocks
A 3 ribt block and a 7 ribt one
the 7 ribt one comes in 2 versions one with oilsquirters and one without them.
with oilsquirters is build since 1991 the 7 ribs is build since 1987.
3 ribs is build since 1982 and released in 1983. The ribs are for a stronger lower block and not for cooling as one might think
Check what you want everything has its advantages.
Turbo and supercharger a great for more power and sprints etc.
NA is perfect for drifting high revving
09-10-2004, 11:57 AM
4A's Engine's
Both the 20V engines are only good for around 140bhp. The valve timing system is no match for the VTEC system. Honda has patented everything thats even similar.
09-10-2004, 01:50 PM
4A's Engine's
nah then can put out more because there held in same like a limiter also the standard jap ecu's are limitet at 185 kmh
the engine doesn't run on its full potential seen one run at 190 Hp at the wheels how fun is that
regards
Lennert
  toyota a series engine....can a fwd corolla engine be used 210 datsun guy 5 8,405 10-30-2013 11:18 PM
  Need engine,any engine Apolan 25 19,649 10-29-2006 06:55 PM
