4AGE + whatever gearbox? Help needed.
12-02-2008, 07:59 PM
Well - as im slowly gathering parts for my rolla while she is in transit - i started to think about new gearbox - cuz T50 will not hold my planed 250hp for sure.. Today i got Altezza 6 speed gearbox from a friend (for FREE Big Grin) just need to put it all back together (its reasembled - and got 2/3gears - totaly new - all synchros - new - and 2 shafts - new Big Grin)
So - im kinda mentaly preparing my self for the gearbox swap - and would like to know what problems will i get Big Grin im kinda fimiliar with the Toyota Engines - and i clearly know that S series trany will not block to A series engine without extensive modifications... I was thinkning about fabricating spare plate - and matching all the holse and etc, or maybe i could use T50 bellhousing and cross it over with the altezza gearbox bell housing?
All the ideas / topics / info about similar tranny swaps welcome Smile Thank guys.
Ex-owner of JDM 83' Trueno Coupe
DCw Classic, classic cars restoration,
JDM wheels & parts import, sales.
http://www.facebook.com/DogCustomWorks
+37067170000
12-02-2008, 08:11 PM
http://forums.club4ag.com/zerothread?id=830
here you can read a LOT about this project.
12-03-2008, 05:56 AM
http://www.toymods.net/forums/showthread.php?t=21207
probably the same thread, just a different forum.
12-04-2008, 07:28 PM
Thanks guys...... yeah both my threads.......
This is how Pineapple Racing and I see it....
[Image: AEU86 AE86 - 4AGE + whatever gearbox? Help needed.]
Crystal Body Yokahama is also working on this..... They are trying it from a slightly different perspective....
http://blog.livedoor.jp/cb_yokohama/arch...08-08.html
Dan -
12-04-2008, 08:03 PM
Both ways are acceptible for me... If pineapple version EVER makes into production - i would be all over it...
If not - i will try the Spacer way first - and see how it goes... I have a spare T50 housing, so i can make 2 mistakes Big Grin Cuz second T50 housing is on my tranny...
+37067170000
12-04-2008, 09:31 PM
Just talked with one local machine shop, and second choise seems to be more or less realistic to make localy Smile And they want around 300 euros for the job (cutting, centering, welding and etc Smile ) so i will go this way i guess Smile
+37067170000
10-11-2009, 09:46 PM
Done. Finally got the housings back from the metal shop Smile Its costed me 400 euro to get this done - but its well worth it especialy then i got the gearbox for free Big Grin
+37067170000
10-11-2009, 10:43 PM
SWEEEEEEEEET - looks very nicely done! Are you using the J160 gearbox?
Dan -
10-11-2009, 11:24 PM
oldeskewltoy Wrote:SWEEEEEEEEET - looks very nicely done! Are you using the J160 gearbox?
Im using SXE10 gearbox from altezza Smile its J160 right?
+37067170000
10-11-2009, 11:34 PM
Doggy take a look at what I've been thru and by your experience let me know what could be best for it, this particular project is on hold because I cant decide the best way to couple engine and gearbox
JonnyAE86;996094 Wrote:Got this baby right here:
To match the Gearbox i had laying around in the shop, a Lexus IS200 one
I was kinda excited I could go ahead with a 3S-GE project on my extra 86 shell but when I started things came to a halt...
Pics show the plate of the Celica 3S-GE and Lexus bellhousing underneath it, red holes are the ones that fit AND most importantly keep the shaft aligned with thhe clutch. Yellow holes are for the starter, the Celica one fits OK, minor problem is the plate is offset, but doable. Green holes are way to far to fit in the block Sad
So, before I start spending money and time on fabricating if anyone can help me out with some pointers I would be very thankfull.
Also:
Celica clutch dont match Lexus shaft!
-Will a Lexus IS200 clutch fit the 3S flywheel?
-Will a JDM Altezza gearbox fit THIS engine?
Thank you for your help Wink
  Help needed totta Crolla 3 4,536 05-15-2020 10:07 AM
Last Post: totta Crolla
  Some wiring help needed DJexor 5 6,258 05-18-2019 01:50 PM
Last Post: DJexor
  Help needed: is it 1 way or 1.5way LSD Dino86 2 4,169 05-17-2019 09:08 AM
  4ac gearbox on 4age hachirokkos 2 7,129 05-24-2016 10:16 PM
  ford type 9 gearbox with 4age engine filh 29 53,152 01-11-2015 01:02 PM
Last Post: filh
