4agZe problem solved - 99% IC problem
07-06-2012, 09:03 PM
Post: #31
Tam dum DAAAAAA? Dramatic music plays...
My stepdad just visited me and he lent me his stethoscoop or whatever you call that.
We listened to the engine together and found out that is probably a cam-shaft-bearing.
Easy to fix or not? Cant find much on the interwebz.
We listened on top of the engine from the oil-cap to the back towards my front window and you could hear how loud it got at the end.
So probably camshaft bearing(s).
We tried this without the belts on and with belts on - so it should be my block then I suppose.
Couldn't hear anything from anywhere else.
-DWG- Drift Wolf Gaming
07-06-2012, 10:58 PM
Post: #32
I dont believe the camshafts have bearings on 4age's..
Pull the cam covers.. see what you find.
07-06-2012, 11:02 PM
Post: #33
Okami Wrote:So probably camshaft bearing(s).
Most unlikely... 4AGE/GZE camshafts run in the head casting and don't
have replaceable shells. To make enough noise to sound like a lawnmower,
you would have to have a broken valve or valve spring, and then you
would (probably) be running on three cylinders.
Cheers... jondee86
07-06-2012, 11:08 PM
Post: #34
Thanks Guys... I found that out later...
Dammit.
I will probably drive the car to toyota upcoming next week but first tomorrow there is a special day for any toyota in Gemert.
They are trying to do a world-record-attempt.
I will go with my wifey's starlet.
Hopefully I will find out what it is soon enough.
Time for a mechanic I suppose.
07-07-2012, 10:14 AM
Post: #35
krukas lager die bijna kapot is? bij renault klinkt dat namelijk ook zo. (wel lastig te beoordelen via de video.) hoe ziet je motor olie eruit?
toyota corolla coupe 1985 drift car
toyota corolla coupe 1987 road car.
07-07-2012, 09:02 PM
Post: #36
slowboy2 Wrote:krukas lager die bijna kapot is? bij renault klinkt dat namelijk ook zo. (wel lastig te beoordelen via de video.) hoe ziet je motor olie eruit?
Motor olie ziet er naar mijn mening normaal uit. Heb nog niet echt iets kunnen vinden.
Maandag maar naar de Toyota dealer.
07-09-2012, 05:11 PM
Post: #37
So... update...
Aparently the IC is the one making the sound.
Very weird.
Probably a loose piece inside of it.
I will see if I can fix it and update you as soon as I can.
07-09-2012, 09:31 PM
Post: #38
http://youtu.be/GauRshupe4M
I rest my case!
I suppose thats it!
07-10-2012, 11:09 PM
Post: #39
Aparently it was the FMIC.
Just ran my car back home and tomorrow will be the big test driving to the spot to test the GT86.
Wish me luck Wink
For now it seems fixed.
I managed to get another FMIC thank God. Pfew!
07-12-2012, 08:05 AM
Post: #40
LOL!
But, hey at least it was easy to solve! Smile
1985 Sprinter Trueno GT Apex
2013 GT86 Miltek Exhaust, Injen Induction.
  AE86 Driveshaft too long? [SOLVED] MyCrazyGarage 12 7,603 07-28-2022 10:48 PM
  4agze wiring problem leon205gti 15 23,042 01-21-2017 09:19 PM
Last Post: leon205gti
  Questions about brake boosters and master cylinders---SOLVED T_AE86 17 25,070 02-02-2012 07:54 PM
Last Post: T_AE86
  [4AGE] ignition timing problem -> SOLVED !! eg6maxx 16 49,947 05-17-2011 11:48 AM
Last Post: eg6maxx
  4AGZE problem...I Need help please guys ash16valve 6 7,099 12-11-2009 04:48 PM
Last Post: ash16valve
User(s) browsing this thread: 27 Guest(s)
