4agZe problem solved - 99% IC problem
07-06-2012, 09:03 PM
Post: #31
Tam dum DAAAAAA? Dramatic music plays...
My stepdad just visited me and he lent me his stethoscoop or whatever you call that. We listened to the engine together and found out that is probably a cam-shaft-bearing. Easy to fix or not? Cant find much on the interwebz. We listened on top of the engine from the oil-cap to the back towards my front window and you could hear how loud it got at the end. So probably camshaft bearing(s). We tried this without the belts on and with belts on - so it should be my block then I suppose. Couldn't hear anything from anywhere else. -DWG- Drift Wolf Gaming |
07-06-2012, 10:58 PM
Post: #32
I dont believe the camshafts have bearings on 4age's..
Pull the cam covers.. see what you find. FABRICA MI DIEM, PVNC! |
07-06-2012, 11:02 PM
Post: #33
Okami Wrote:So probably camshaft bearing(s). Most unlikely... 4AGE/GZE camshafts run in the head casting and don't have replaceable shells. To make enough noise to sound like a lawnmower, you would have to have a broken valve or valve spring, and then you would (probably) be running on three cylinders. Cheers... jondee86 |
07-06-2012, 11:08 PM
Post: #34
Thanks Guys... I found that out later...
Dammit. I will probably drive the car to toyota upcoming next week but first tomorrow there is a special day for any toyota in Gemert. They are trying to do a world-record-attempt. I will go with my wifey's starlet. Hopefully I will find out what it is soon enough. Time for a mechanic I suppose. -DWG- Drift Wolf Gaming |
07-07-2012, 10:14 AM
Post: #35
krukas lager die bijna kapot is? bij renault klinkt dat namelijk ook zo. (wel lastig te beoordelen via de video.) hoe ziet je motor olie eruit?
toyota corolla coupe 1985 drift car toyota corolla coupe 1987 road car. |
07-07-2012, 09:02 PM
Post: #36
slowboy2 Wrote:krukas lager die bijna kapot is? bij renault klinkt dat namelijk ook zo. (wel lastig te beoordelen via de video.) hoe ziet je motor olie eruit? Motor olie ziet er naar mijn mening normaal uit. Heb nog niet echt iets kunnen vinden. Maandag maar naar de Toyota dealer. -DWG- Drift Wolf Gaming |
07-09-2012, 05:11 PM
Post: #37
So... update...
Aparently the IC is the one making the sound. Very weird. Probably a loose piece inside of it. I will see if I can fix it and update you as soon as I can. -DWG- Drift Wolf Gaming |
07-09-2012, 09:31 PM
Post: #38
07-10-2012, 11:09 PM
Post: #39
Aparently it was the FMIC.
Just ran my car back home and tomorrow will be the big test driving to the spot to test the GT86. Wish me luck ![]() For now it seems fixed. I managed to get another FMIC thank God. Pfew! -DWG- Drift Wolf Gaming |
07-12-2012, 08:05 AM
Post: #40
LOL!
But, hey at least it was easy to solve! ![]() 1985 Sprinter Trueno GT Apex 2013 GT86 Miltek Exhaust, Injen Induction. |
AE86 Driveshaft too long? [SOLVED] | MyCrazyGarage | 12 | 7,638 |
07-28-2022 10:48 PM Last Post: banpei |
4agze wiring problem | leon205gti | 15 | 23,124 |
01-21-2017 09:19 PM Last Post: leon205gti |
Questions about brake boosters and master cylinders---SOLVED | T_AE86 | 17 | 25,194 |
02-02-2012 07:54 PM Last Post: T_AE86 |
[4AGE] ignition timing problem -> SOLVED !! | eg6maxx | 16 | 50,014 |
05-17-2011 11:48 AM Last Post: eg6maxx |
4AGZE problem...I Need help please guys | ash16valve | 6 | 7,107 |
12-11-2009 04:48 PM Last Post: ash16valve |
User(s) browsing this thread: 17 Guest(s)
