4age 16v starting and running problems
02-10-2012, 02:15 PM
I've been having trouble for a while now with my car being hard to start, everytime you start it the timing seems to advance and retard, so you start it first time it runs on 3 cylinders, you turn it off and start it again and it runs slightly better, turn it off start again and it might run perfect
it was always running perfect once it was got going I thought it was the ecu but I swapped another one in and its the same anyone seen this before any help would much appreciated' |
02-11-2012, 01:37 PM
Have you checked for error codes ?
When you check for error codes you can run the engine with the check connector shorted, this should lock the ignition timing and at idle it needs to be around 10 degrees BTDC An analogue brain in a digital World |
02-11-2012, 05:50 PM
i don't think this will help as when its running, it runs perfect, its only tryin to start it thats trouble
No idle below 2000 rpm rich running | Steller Engineering | 3 | 1,386 |
Running issues | sam3007 | 6 | 2,731 |
Big wheel problems | gh0st | 16 | 7,990 |
lntermittent starting | totta Crolla | 6 | 3,525 |
08-31-2021 06:21 PM Last Post: totta Crolla |
Starting problems 4-AGE kouki | Hanzo | 3 | 2,582 |
