4age 16v starting and running problems
02-10-2012, 02:15 PM
I've been having trouble for a while now with my car being hard to start, everytime you start it the timing seems to advance and retard, so you start it first time it runs on 3 cylinders, you turn it off and start it again and it runs slightly better, turn it off start again and it might run perfect
it was always running perfect once it was got going
I thought it was the ecu but I swapped another one in and its the same
anyone seen this before
any help would much appreciated'
02-11-2012, 01:37 PM
Have you checked for error codes ?
When you check for error codes you can run the engine with the
check connector shorted, this should lock the ignition timing and at idle it needs to be around 10 degrees BTDC
02-11-2012, 05:50 PM
i don't think this will help as when its running, it runs perfect, its only tryin to start it thats trouble
  No idle below 2000 rpm rich running Steller Engineering 3 2,136 11-30-2022 02:45 PM
Last Post: RolanTHUNDER
  Running issues sam3007 6 3,694 06-26-2022 01:34 PM
Last Post: Dave W
  Big wheel problems gh0st 16 10,219 11-15-2021 10:51 PM
Last Post: gh0st
  lntermittent starting totta Crolla 6 4,530 08-31-2021 06:21 PM
Last Post: totta Crolla
  Starting problems 4-AGE kouki Hanzo 3 3,334 08-31-2021 06:20 PM
