4age 20v A/T ecu
07-09-2008, 09:52 PM
4age 20v A/T ecu
can i run my 4age 20v with an automatic transmission ecu if i have a manual transmission? will the engine loom fit?
07-09-2008, 10:20 PM
4age 20v A/T ecu
the automatic transmission would initiate the clutch and shift procedure. Don't think that is a winner. Just go standalone.
07-09-2008, 10:23 PM
4age 20v A/T ecu
in my Nissan i can use a auto ecu on a manual car without any problems..
07-09-2008, 10:27 PM
4age 20v A/T ecu
yep it's possible, you have to find the wire for the Park/Neutral signal in the loom and connect it to ?? (12V i guess), otherwise your car won't start, because the ECU thinks it's in Drive Smile
07-09-2008, 10:40 PM
4age 20v A/T ecu
it is a manual loom, so there wont be a park or neutral wire.
but there must be a pin on the ecu that is park or neutral.
07-09-2008, 11:01 PM
4age 20v A/T ecu
yeah, that's what i mean.
If you're unlucky, the connectors aren't the same on the ecu and loom
07-13-2008, 10:52 PM
4age 20v A/T ecu
I've heard rumors as well that thhe A/T has a higher redline, and that switching on the extra wires is a piece of cake.
Fully Restored 1985 Corolla GT-S
1987 328ci SR20DET Drift Car
1989 Honda Civic Si-R Current Project
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
07-14-2008, 10:21 PM
4age 20v A/T ecu
Yes that higher redline might be interesting too, but no one over here used a A/T ecu?
  20v Silvertop - New Haltech ECU & Couple of questions 20valver 10 2,310 05-26-2024 07:40 PM
Last Post: totta Crolla
  Ecu for AE86 4AGE Steller Engineering 6 5,211 03-10-2021 11:06 PM
  20v BT conversion ECU izanagi 5 6,851 06-14-2016 02:39 PM
Last Post: izanagi
  20V blacktop. what kind off ecu??? slowboy2 11 13,837 07-17-2015 07:01 PM
Last Post: jdm86gtz
  4age 16v oem ecu rev limiter research ditn 18 28,219 06-22-2015 08:02 AM
Last Post: ditn
